hey guys, i need some help
when i turn on my head lights my passenger side turn signal stays lit, and my left turn signal light in my dash stays lit
what the hell causes this? i have no idea where the check my wiring, and i just finished replacing every damn bulb in the stupid thing
i have to take it for a safety on friday morning and it will fail cuz of this
ALSO
i am still ushing a lot of condinsation out of my tail pipe
i am getting a new o2 sensor tomorrow
i have a small exhaust link, but i don't think thats whats causing it. any ideas? the etest is at the same time as the safety...lol
starting to get nervous, don't want to waste my 130 bucks
I have found, that, my jeep's socket on the RS turn signal was suspect. your issue may be due to a bad/broken ground or not making contact with the light bulb. check for ground issue first then see if the light bulb is making contact. a plus for you would be if you have any eletronic techy friends that have some tools that help isolating this issues. :brows:
Definately the sockets, had that problem on both of mine. You can get a junky Ford plastic one at most parts stores that will work. The best replacement I've found is the metal ones off a donor XJ at the pull a part. The grounds inside the sockets is the culprit.
Agreed....I just had to replace a RF socket because of a ground issue in it. I found one at Autozone that worked, but it is not a "perfect" fit.
I found one at Advance Auto that IS a perfect fit. It's listed for a Ford, but I don't remember which year and model.
expensive?
where is the ground located at (not in the bulb)
safety guy said i have a bunch of lights i need to fix
I HATE ELECTRICITY
PS.
passed the etest, almost passed the safety. some small brake issues, and some electrical gremlins. Thanks for the help everyone
