I thought about this for my axle to keep lug pattern and unit bearing simplicity, but its just not worth the weak c and knuckle. I would never even consider putting hydro assist to that front end. Basically if you can bend the C's, tubes and break off knuckles knowing your running a 30 then there is no point in creating the false sense of security in having a 44 with those outers. JMO
Brace that C!!!!
