89comancheowner Posted July 13, 2011 Share Posted July 13, 2011 What is the difference between a 2 wheel manual trans and a 4 wd manual trans. like adaptability. Link to comment Share on other sites More sharing options...
Walkenvol Posted July 13, 2011 Share Posted July 13, 2011 Can't bolt a transfer case to the 2wd transmission. Link to comment Share on other sites More sharing options...
jimoshel Posted July 13, 2011 Share Posted July 13, 2011 The bolt pattern where the extension housing and the transfer case bolt up is usually the same. Biggest difference is the output shaft. On some models you can just remove the ext housing and the TC will bolt up OK. On on others, it will be necessary to swap the tranny output shaft. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted July 13, 2011 Share Posted July 13, 2011 What do you mean "adaptability"? If your talking converting a 2wd to 4wd, then a 2wd manual transmission has a longer mainshaft and tail housing, that is why it is not practical to convert a 2wd tranny to 4wd. Link to comment Share on other sites More sharing options...
89comancheowner Posted July 13, 2011 Author Share Posted July 13, 2011 thank you for your answers looks like i need a 4wd trans the Cherokee that i am getting is 4wd and my truck is not but the trans is bad in the cherokee so I can rebuild mine with that output shaft? Link to comment Share on other sites More sharing options...
jimoshel Posted July 14, 2011 Share Posted July 14, 2011 Yes, if they're the same make, model. Link to comment Share on other sites More sharing options...
