MJCrusader Posted June 25, 2011 Share Posted June 25, 2011 I keep seeing members talking about what to do if the hood release breaks, and that it should be lubed regularly. But, I haven't seen anyone say or post a picture of what should be lubed and what it should be lubed with. Can somebody go into a little more detail for me? Thanks, Tim Link to comment Share on other sites More sharing options...
64 Cheyenne Posted June 25, 2011 Share Posted June 25, 2011 Every now and then I use a little bit of spray on white lithium grease on the mechanical latches. For the cable, when I change the engine oil I put a few drops of clean engine oil on the end of the cable, let gravity move it into the cable, works smooth like butter. don't use WD-40 for this, it is not a suitable lubricant. Link to comment Share on other sites More sharing options...
SW86 Posted June 25, 2011 Share Posted June 25, 2011 i put 3-in-One oil on all the the hood release parts. kind of tricky on the latches but a straw works wonders getting in there. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 25, 2011 Share Posted June 25, 2011 Been using Dri-Slide on my motorcycle cables for years and tried it on the hood cable. It has a needle applicator that you can insert into the cable sheath and squirt it in until it flows out the other end. It's nice as it does not gum up. Can pull the hood release cable with two fingers now. Good stuff. Link to comment Share on other sites More sharing options...
terrawombat Posted June 25, 2011 Share Posted June 25, 2011 Initially, I hit the hood latch mechanism with Kroil to really free it up. Now I use the spray-on white lithium grease during oil changes to keep it lubed up. Link to comment Share on other sites More sharing options...
