Boots Posted June 17, 2011 Share Posted June 17, 2011 How does the bushing come out of the shackle?? It looks like it's crimped in there or some thing. Ive already tried using two sockets and a hammer and/or vise.(like a u-joint) Thanks Link to comment Share on other sites More sharing options...
dakal Posted June 17, 2011 Share Posted June 17, 2011 if its like the control arm bushings it takes a 20000 ton press. Link to comment Share on other sites More sharing options...
MJRemi Posted June 17, 2011 Share Posted June 17, 2011 I've read that heating it with a torch or even burning it out are common methods. Just be sure you are outdoors if you decide to burn out the bushing. If you are able to place the shackle in a vice, you can pound out the bolt sleeve with a same size socket and then the bushing should come right out (maybe). Good luck! Link to comment Share on other sites More sharing options...
philbert001 Posted June 17, 2011 Share Posted June 17, 2011 if its like the control arm bushings it takes a 20000 ton press. :huh???: I've always used a hammer and a block of wood! What are you pushing em out the wrong side? Link to comment Share on other sites More sharing options...
philbert001 Posted June 17, 2011 Share Posted June 17, 2011 Oh! You are talking about re-using the sleeve! Why? You can knock the whole sleeve out of the control arm, then get new bushings, sleeves and all! (If you are upgrading to urethane bushings, in stock control arms, I gotta ask, "Why?") You can get 4 oe style LCA bushings, in sleeves, for $50-$60! Link to comment Share on other sites More sharing options...
dakal Posted June 18, 2011 Share Posted June 18, 2011 re control arms, using their bushing. they recommend the 20000 ton press. and yes it took a lot on the press to get them out. not so much on installing them. Link to comment Share on other sites More sharing options...
philbert001 Posted June 18, 2011 Share Posted June 18, 2011 re control arms, using their bushing. they recommend the 20000 ton press. and yes it took a lot on the press to get them out. not so much on installing them. Wow! Least you don't have to worry about them being sloppy! Link to comment Share on other sites More sharing options...
dakal Posted June 18, 2011 Share Posted June 18, 2011 on a side note: the bushing they sell ,the center is a flat piece of metal bent into a round shape. this is true of all the ones i've seen. i would like in the future to have round stock as the inter part. so if anyone knows who makes one , please post where to buy, or what to buy. fitting a round bolt into a oval hoe isn't my idea of smart. Link to comment Share on other sites More sharing options...
grabber Posted June 18, 2011 Share Posted June 18, 2011 I rented a bushing press from Adanvce Auto used a 1/2 drive and a breaker bar, had them out in about 45 min Link to comment Share on other sites More sharing options...
