my lower control arm bolts are rusted to the steel tube in the rubber bushing so I'm going to have to cut them out. I know they are metric and will be expensive if i can even find a hardware store that sells metric bolts that big. Will a close fitting SAE bolt fit well good enough to use? I'm not even sure what diameter the metric bolt is so i thought i would ask in here. thanks
Mmm...
9/16th Gr8 SAE will be close I think. Providing those bolts are 10.9s - not 12.9s. If they're 12.9s, go to junkyard and get 'new' ones.
But, that's going by memory.
Dirty,
That sounds right to me.
I bought the dealer bolts one time.....EXPENSIVE!!! Something like $5.00 each NUT than $12- 17 for each bolt!!
I would go to a good hardware store and get Grade 8 stuff next time!!!
CW
you might check the online stores.. rustys probably stocks them, (can't screw up that can you?) and rubicon express has them as well... unless their kits don't replace those? but that would be odd.
