I have a 98 mj and put 99 Cherokee doors on it, they fit fine but the pass door was bad so I got a 97 Cherokee pass door and it doesn't fit, big gap by cab corner side and now hits fender, I put another shim on top and bottom but won't shut, I really just want to know if different year doors are shorter or longer or what can I do :dunno:
you mean you have an 88 MJ? lots of parts are interchangeable, some require a little creativity to make it work but you can. the doors should be the same size. you may just have to keep messing with the shims.
Sorry it's a 89 eliminator short bed and thanks for info. Went to dungeon and found out my hinges were bent out some, but also my latch is shot, so now I have to order a latch and new fender and hope it all works. Then she is going to the shop to get new rockers and floor boards then sanded and painted
