Picture?
You cut the perches off the top of the axle tubes and weld them onto the bottom. It'll end up looking exactly like the axle that's in your MJ. The XJ axle also has shock mounts on the tubes -- you can cut those off, or leave them in place.
The critical issue is getting the angle of the perches to the pinion correct. If you're not lifting, use the old MJ axle as a template and match it exactly. If you're lifting, you'll have to calculate the correct angle.
It will be alot easier with a pic or write up. I understand what ur saying but i need to be sure.
Sorry its 4:23 am
please tell me your not going to wing it. cause thats what that statement made it sound like :no:
