no voltage at the fuel pump ?????
I've chech almost everything
the pump work
the resistor on the fender show 1.2 homs
all fuse link are ok
all relays are ok
but I get no voltage at the pump and at the conector #157 behind the kick panel on LH side
the only thing I have not check is the engine CPU
is there a sensor or something other then the ones mention above that, if it does not work, won't allow voltage at the pump?
TY
Did you check the fuel pump relay on the right inner fender? there are 4 relays between the starter relay and the diagnostic connectors. from front to back they are oxygen sensor heater relay, fuel pump relay, power latch relay, a/c clutch relay. If all are ok it may be a broken wire.
the pump work
all relays are ok
TY
I will check that seems resonable that a wire would be bad to the relay
I was about to start checking that because all components of the circuit are good
but as you know there are a lot of wires to check ............ :mad:
all right, fault finding done and I got no power comming from the fuzelink wire
I also tested continuity between the #87 prong and the relay and the #139 connector at the fuel pump and its all good
I did replace the fuzelink with a fuse holder
a 20 gauge fuzelink = how many amp fuse???????
just to make sure I'm not putting a fuse to big for the circuit 20A I'm guessing
the prob is between the starter relay and the #30 prong on the fuel pump relay
tomorow I will open the wire pack and look for the faulty wire if I can't find it I will just put a new one
more to follow
well the asd relay kicks in
the CPS is ok and the cam sensor to
any ideas to what to check next
what can cause the asd to activate ?
the truck is sold and I need to get it going please input on this............
  • 3 weeks later...
