OMG! I was about to ask about this as well.
My truck has been making a god awful deep vibration coming from the rear which I'm assuming is a bad bearing. Well here's my question.
I work at Advance Auto Parts and for some reason our computers don't have the AMC 20 under my 86 comanche. I was wondering if the bearings and everything are the same from a CJ-7 AMC 20?
Yes, the seals and bearings are the same as 81+ FSJ.... which are also the same as a D44 set 10.
Part numbers below. See the manual for pics/diagrams. You can google search the part number to find it for sale, or a cross reference application.
http://www.jeep4x4center.com/jeep-parts ... atalog.pdf
Page 87 of 1741: DIFFERENTIAL AND GEARS, REAR AXLE AMC LARGE AXLE, NON-LOCKING COMANCHE
# J3182601 NUT, Pinion
# 83502058 YOKE, Pinion
# 53002642 SEAL, Pinion
# J3172135 CONE, Bearing
# J3172134 CUP, Bearing
# J3175971 SPACER, Pinion
# J3205567 SHIM PACKAGE (18), Pinion ***
# J3172564 CUP, Bearing
# J3172563 CONE, Bearing
# J8127072 GEAR SET, Rear Axle Ring and Pinion
# J4486828 BOLT PACKAGE ***
# J3235502 CASE ASSEMBLY, Differential
# J8127092 GEAR SET, Differential
# J3220250 WASHER, Side Gear
# J3222999 WASHER, Pinion Gear
# J3218195 SHAFT, Differential
# S0455313 PIN
# J3205532 SHIM PACKAGE (18), Case ***
# J3172565 CONE, Bearing
# J3172566 CUP, Bearing
Page 88
DIFFERENTIAL AND GEARS, REAR AXLE AMC LARGE AXLE, LOCKING COMANCHE
J3185971 SPACER, Pinion
J3230153 CASE ASSEMBLY, Differential
J8120326 GEAR SET, Differential
J8120325 DISC PACKAGE, Differential ***
J8121787 RING, Snap
Page 89: SHAFT, REAR AXLE AMC LARGE AXLE COMANCHE
53001262 SHAFT, Axle
J3220275 STUD
53000460 PLATE
53001953 RETAINER
J3240086 SEAL
J3230115 BEARING
J3239074 RING, Retaining
53001524 SHAFT ASSEMBLY, Axle
