duster1971 Posted April 21, 2011 Posted April 21, 2011 Any body know where to find cab corners for the comanches? I have looked and can't seem to find them floor pans on the other hand are simple to find fenders are to. But the outer corners are in bad shape on my mj and I wuld like to get them replaced before the inners start rusting away.
jeff Posted April 21, 2011 Posted April 21, 2011 I am having the same issue but I'm looking for both inner and outer.
87Warrior Posted April 21, 2011 Posted April 21, 2011 From another MJ. The sticky in regards to patch panels had some momentum with replacement cab corners, but I don't think anything ever came of it. My body shop guy said he could, and has repaired MJ cab corners. It would be expensive. I was lucky enough to find a scrap truck that had good corners, so I cut them out. If you are worried about rusting out the inner metal, why don't you pull the seat/b pillar plastic, reach into the corner, sand away and then treat with POR15 or a similar product? At least you could protect the structure of the cab back. I will say that my cab corners were pretty rough, but it is the front part of my inner rocker that needs the most work. I kind of want to make a mold of the corners I have. Maybe somebody could use them to make duplicate corners for us, I don't know.
duster1971 Posted April 21, 2011 Author Posted April 21, 2011 I was realy hoping to just find some. If I have to I will just get some sheet/metal and bust out the body hammer set and go to work there is enoff of the corners there that I can shape the metal around then cut and weld I just wish there were more parts for these trucks.
glundblad Posted April 21, 2011 Posted April 21, 2011 I needed two cab corners. The body shop was able to form the piece that needed replaced on one. On the other, too much of it needed replaced so I had a JY cut one off a donor. They charged me $40 for it. Just have them cut above the angles on the top and past the seams on the back and toward the underneath side.
duster1971 Posted April 22, 2011 Author Posted April 22, 2011 If I can't get both mine formed then I will have to call around to the jy and see if anybody has some. Realy hope I don't have to do that but if I do then I do.
