duster1971 Posted April 13, 2011 Share Posted April 13, 2011 any body have pics of the ax 5 and ax 15? i was told that my mj had the ax 15 now I'm unsure.i have a spare tranz out of my 87 dakota that I'm unsure of aswell. thanks in advance for any info/pics. Link to comment Share on other sites More sharing options...
Geonovast Posted April 13, 2011 Share Posted April 13, 2011 4.0 used AX-15 mid 89-99 2.5 and 2.8 used the AX-5 Â AX-5 left, AX-15 right Link to comment Share on other sites More sharing options...
duster1971 Posted April 13, 2011 Author Share Posted April 13, 2011 thanks verry much. wish i had ax15 now. so what is the major issues with the ax5? Link to comment Share on other sites More sharing options...
jimoshel Posted April 13, 2011 Share Posted April 13, 2011 It's not as strong as the AX15. Behind the 2.5 and 2.8 it will run forever. Behind the 4.0 it will break. Actually if you baby it, it will last behind the 4.0, but if you're going to baby, then what in H*ll you driving a Jeep for? Link to comment Share on other sites More sharing options...
duster1971 Posted April 13, 2011 Author Share Posted April 13, 2011 no babying here. so it seems i am good with my 2.5 ax5 combo. if i ever upgrade to the 4.0 then i will look for the ax15 behind it. so my 87 dakota trans looks nuthing like them any idea what it may be? Â nevermind i went and found the tag on the dakota trans its a np a535 trans these any good? Link to comment Share on other sites More sharing options...
Geonovast Posted April 13, 2011 Share Posted April 13, 2011 no babying here. so it seems i am good with my 2.5 ax5 combo. if i ever upgrade to the 4.0 then i will look for the ax15 behind it. so my 87 dakota trans looks nuthing like them any idea what it may be? nevermind i went and found the tag on the dakota trans its a np a535 trans these any good?  There's no bellhousing out there that will allow you to put an AX-5 behind a 4.0 anyway. If you do a 4.0 swap, you'll find 3 different 5 speeds behind it:  Pukey BA 10/5: 87-mid 89 AX-15 : mid 89-99 NV3550 : 00-01  Those are for the XJ anyway, I'm not entirely sure if the YJ/TJs used the same years, but they used the same transmissions. Link to comment Share on other sites More sharing options...
duster1971 Posted April 13, 2011 Author Share Posted April 13, 2011 thats good wuldnt want it there if there was. seeings how theres not don't have to worrie bout it any way. Link to comment Share on other sites More sharing options...
jimoshel Posted April 13, 2011 Share Posted April 13, 2011 no babying here. so it seems i am good with my 2.5 ax5 combo. if i ever upgrade to the 4.0 then i will look for the ax15 behind it. so my 87 dakota trans looks nuthing like them any idea what it may be? nevermind i went and found the tag on the dakota trans its a np a535 trans these any good?  There's no bellhousing out there that will allow you to put an AX-5 behind a 4.0 anyway. If you do a 4.0 swap, you'll find 3 different 5 speeds behind it:  Pukey BA 10/5: 87-mid 89 AX-15 : mid 89-99 NV3550 : 00-01  Those are for the XJ anyway, I'm not entirely sure if the YJ/TJs used the same years, but they used the same transmissions. Don't need no stinkin bell housing. That's what duct tape is for. Link to comment Share on other sites More sharing options...
jeepsouth Posted April 13, 2011 Share Posted April 13, 2011 Duct tape! :rotf: Link to comment Share on other sites More sharing options...
