NewfieMJ Posted April 10, 2011 Share Posted April 10, 2011 The name is dedicated to my late father-in-law . He was grumpy , stubborn , missing some parts , and even parted himself out (research) . When he finally quit , you couldn't have been more proud , or surprised he lasted so long . As you can tell , his charactor was quite similar to a Jeep :bowdown: , now , on to the show Here's my $300 investment . 1988 MJ Pioneer , 2.5 , 5 speed SWB The body was in really nice shape . Bottom door corners where bad though . The PO had cobbled a fix with fiberglass , I have other plans :) . Here's a few pics after I trailered it to the car wash First order of buisness was to get it mobile . The 2.5 had been cooked from the story I got , so , I never even bothered to attempt a fix . I found a 1990 YJ with 95K and got the engine , plus a head gasket kit for $450 . I got the gasket set because I thought there was a problem . After several tests , it was discovered the YJ has a standard rotaion water pump , the MJ's is reversed . I got a new rad , water pump , t-stat , and lower rad hose , should stay cool now . The PO also installed a new clutch fan and blade :) . When I pulled the engine , it was no surprise to see the old clutch had seen better days . Although this powertrain may be temporary , I don't need the clutch to fail . Si I had the flywheel machined and bought a new clutch kit Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 10, 2011 Author Share Posted April 10, 2011 Engine is in , and runs great . I also ended up installing a new muffler and 3' of pipe too . Clutch works great also , it was my first clutch job , easy stuff . Took it for a quick ride around my block , all works good , the powertrain I am now happy with . The suspension and steering , well , it need a track bar and new shocks . I know that just from the ride , lol . The interior isn't pretty at all . 22 yrs has not been overly friendly to it . The seat did remain intact , just dirty . The carpet smelled like a 22yr old carpet would , phew .Here ya go Carpet had to go . Besides , every MJ owner wants to really know what kinda shape his MJ is in . After reading alot of build threads before starting , I was quite pleasantly surprised to find this I gave it a quick cleaning , scuffed what little rust was there , sanded and just hit it with some blue paint to cover the metal . I plan to undercoat the floor before installing some new carpet , but , the buckets found their home . Guess it's time to show you a donor for this project . Here's my 1998 XJ with a bad piston skirt knock . It's got 260K Here it is again , missing a few parts :D So is the MJ now too Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 10, 2011 Author Share Posted April 10, 2011 There are very few changes to be made to fit the new parts . These brackets have to be swapped to mount the fenders/headerpanel This vacumn cannister has to be swapped out to the new bumper , which it bolts onto once the XJ's can is removered . Here's a pic of the inner fender . I ended up painting the upper area , and undercoating the wheel well area , sorry , never got a pic of the after shot The doors are where I began , they are a royal PITA . Lots of tweeking to get them right on the alignment , then , one has to deal with the door post anchor . Mine were welded for the easy solution . The fenders go pretty smoothly . I left the original hood in place to get the gaps correct . This worked really good , the header panel slipped right into place and fit perfect . All lines are good . When I changed the hood , it was a simple one time bolt on , no adjustment required process . Another shot of the interior with the new door panels . I also added the XJ's console which isn't in these pics . I just had to have cup holders :yes: Yeah , they are 4 dr switches but I'll somehow manage to live with them , lol . Last pic of the weeks progress , all bolted back together :thumbsup: Tomorrow I'm hoping to wire up the header panel . No , the wiring is not plug and play . I wish ! I'll be cutting the plug in off the MJ's header panel , and then from the XJ's harness to make an adapter , after the multi-meter gets a work-out , lol . I'm gonna get a friend to tackle the power windows , locks and power mirrors . If I have to do it , the doors won't get tied together :fool: Link to comment Share on other sites More sharing options...
mj Mike Posted April 10, 2011 Share Posted April 10, 2011 nice work! :clapping: I wish i had a sweet late model donor like that! Yeah , they are 4 dr switches but I'll somehow manage to live with them , lol . :yes: Welcome to the club, it still beats the old doors! Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 10, 2011 Author Share Posted April 10, 2011 Thanks Mike Here's a few pics of the console . It's all fitted in now . Still need a touch up to the heating system and something to cover the gap . All in all , easy swap , very functional , and it's a clean look . Nice upgrade for anyone . :thumbsup: Link to comment Share on other sites More sharing options...
mj Mike Posted April 10, 2011 Share Posted April 10, 2011 Any plans for A lift kit? Or 4x4 swap? Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 11, 2011 Author Share Posted April 11, 2011 Lift ? Yeah , it's gonna be tough not to . 4x4 ? Absolutely . Usable to the build parts in my garage : IRO lower adjustable arms RE upper s/flex 2-4.5" OME springs RE HD track bar Full V8 ZJ steering , including new steering gear (depending on final lift height , I may go OTK with the steering and OTA with the track bar . A WJ conversion like I have on my 95OrvisZJ would be great) HP30-3:55 8.25-3:55 4 procomp hydro shocks 242 t-case driveshafts from the 91 eliminator 32x11.5 BFG AT's on Eagle wheels All I really need are some disco's , buy the $130 trans I found , move the 8.25 perches .75" each on the 8.25 , and install some rear discs , which I have also . Yeah , I had a pile of parts before even buying this truck . I want to keep it very streetable , I have 1 jeep with a big lift already , 7.5" F&R IRO LA's , Clayton spring and HD track bar , Bilstien long travel shocks , Trac lock'd D44A(still have to truss) LP D30 going in next week , lsd with electric locker . It went places before I thought I would never get , with the front lock'd ,this thing is almost unstopable , only the trans remains original "everything" else was rebuilt or replaced ie: the 5.2 has only 45k from a 2001 Ram rollover This is what I want , just a little higher on the 32's mentioned . Same paint scheme . I just love this truck :drool: , mine's gonna be better , I have the XJ doors ;) I guess I'll never know the inconvienance of having a useless non functional side window :banana: Link to comment Share on other sites More sharing options...
MancheKid86 Posted April 11, 2011 Share Posted April 11, 2011 wire up the rear of the 4 door switches to use the front/back winches (if you get some) :D Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 12, 2011 Author Share Posted April 12, 2011 I got the lights all wired up and working . Even the side marker lights blink alternately :D I was up late last nite so I also took on painting the grille and headlight bezels white . I think it's such a clean look , I love it . I'm gonna paint the steel on the bumper white next , I think ,lol . Every now and then a guy needs an inspiration shot , so , I pulled out the 32's and stuck em on at stock height . Looks real cool but would require alot of trimming for sure . I adjusted the height to see where the wheels would fit with the least amount of trimming , definately looking at 4-5" , 3" would be the lower max I would do . It would need lots to clear , well , too much for what I want . So , I guess the next plan of attack is to get the front end outta the XJ , and into the MJ with all the lift parts . I'm so close to pulling the powertrain I just refurbished out . I really antidisestablishmentarianism that cursed dash . I have my buddy checking out the wiring in the FSM to see if I could use the dash w/o the insturment cluster . Obviuosly , I'd do a custom one and have mechanical guages . There's a few factors to check out such as making a check engine light but because the heater controls only need a vacumn source and a 12v source to work , that part should work fine . The rest should also be able to be wired in with a little effort . If this does pan out or looks like it's gonna be more trouble that it's worth , I'm gonna pull the power train from the XJ . Swap it in with the rebuilt 4.0 in the 91MJ and go from there Doing this means an auto , which wifey likes , cause the XJ has the AW4 . Rant off , here was the painted grille , stock on 32's Link to comment Share on other sites More sharing options...
Rymanrph Posted April 13, 2011 Share Posted April 13, 2011 The white looks great! Part of me really wants to paint mine white. Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 16, 2011 Author Share Posted April 16, 2011 Front lift has been installed . I only got 3", maybe 3.5 outta the TJ 4.5 springs , :???: . Well , maybe the ZJ V8 w/winch and bumper they supported screwed 'em , LOL , but , oddly , they didn't loose any height on the ZJ . SOA will mean adding a 2" BB which I really wanted to avoid . I have been in touch with Rusty's and may order the 4" leaf packs , then just a 1.5 spacer (I think). I really like the stance of the truck as it sits in the pics , 3.5 frt 3" rr . 1 more inch shouldn't make much more difference . Here's a few pics of the suspension , no , nothing has been tightened up yet and I still haven't decided which track bar I'm using . I might just toss on the cheap @$$ one from RRO for now . The RE bar I want still sits on my ZJ , I need to swap out the Claytons I have for it , before I can get it on the MJ . The RRO bar has a good bushing and new Moog TRE , should be fine for 2WD . Yes , it's adjustable too . Remember , I will eventually go 4x4 . Just a Baja 2wd for this summer , unless I really hate the 4-banger ;) Link to comment Share on other sites More sharing options...
codymanche Posted April 17, 2011 Share Posted April 17, 2011 looks good man like the interior Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 20, 2011 Author Share Posted April 20, 2011 So it's all together again , for now , lol . Today I ordered some 4"leafs , I just hear nothing that positive about aal's or shackles . I figure I'd need to do the bushings anyways so I'm just gonna do a whole new set . SOA was almost done but it's higher than I desire . Here it sits awaiting rear springs I got about 2 weeks before getting my springs so , I'm not sure what to take on next . I do need new brakes , they really suck on the MJ , so , I will probably take the XJ back in and swap the front axles . The XJ has new brakes and I need the diff eventually anyways . Maybe swap the brake booster too . I'm contimplating swapping the dash also and building an insturment cluster with custom guages . I had my electrical wiz friend look into it and he says that it wouldn't be much of an issue at all . Hmmm , this would be cool . I'm liking this idea . He's gone through all the wiring diagrams for the 98 and believe me , this guy knows his stuff . So , I may start taking the dash apart . We are going to look at things this coming weekend . I could do a full swap , but , with the price of gas going up , and not needing a powerhouse , I plan on keeping the 2.5 for a while . I got 3 vehicles with about 300hp or more , this is a miser build :) . It's just for the wife to pull a few garden odds and ends around in the summer time and for me to use on the weekends popping to town and back . I do love this little truck though . Maybe it's because it's different . I don't see many around anymore . I'm glad I did the 98 body conversion , and the white paint will look great too when completed . Been enjoying the other build threads also , some really nice MJ's on the board . Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 27, 2011 Author Share Posted April 27, 2011 Been a not so busy week on the MJ . Needed to stand back and see what I was building . Make some more plans and start again . My rear springs from Rustys came early . Not too bad an install . Only had trouble with onle stubborn bolt . The battle ended with the grinder . Murphy's law dictated it also had to be the one closest to the gas tank . SOB . I used a small sheild even though my spray was away from things as best as could , still , I wondered if things were gonna blow . Well , I made it w/o incident thankfully . :D BTW , the rusty's springs which are suppose to be only 4" , got me a little more . 6.25 to be exact . One has to remember this is a 2wd and is 1" lower than a 4x4 , so , once things settle , I would still say 4.5" (compared to 4x4) outta the springs . I'm gonna add some 1.25 pucks I have to the front , that should give a slight rake . My ZJ shocks didn't pan out quite long enough . My eye to eye parked is a whopping 26" . I'm picking up shocks tomorrow morning that go from 18-32" . Best I can find local and cheap , pro-comps . Stiff shock , soft spring , might be ok , lol . Here's a few of the latest pics Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 27, 2011 Author Share Posted April 27, 2011 And , a few more Link to comment Share on other sites More sharing options...
freakjeep93 Posted April 28, 2011 Share Posted April 28, 2011 your mj has an awesome stance . i like it Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 28, 2011 Author Share Posted April 28, 2011 Thanks for the comments so far . White is definately gonna be a nice color on this MJ . I was gonna go with 'intense red' but the interior would be a very poor match , lol . I like the stance too , but , don't let the pics fool ya , it's raked too much to the front . I have 2" and 1.25" pucks , so , I think the 1.25's are going in the front . Let to start running on the road are the following -pick up and install new rear shocks -new front brake lines -drop e-brake bracket -new rear line (stock , moved bracket , worked great , rubber lines are cracked up) -install ZJ V8 steering -get new windshield 5 outta 6 I should get accomplished today . I'm sure the list will grow once it's on the road and I get a feel for it , but , it should be OK to go . Guess I better get a pink card for it today so I can get it registered :brows: . Lastly , it's time to get my big compressor hooked up . I need to pull the box and get all the body work done so I can get it painted . Been a long long time since I have sprayed anything . White is a great color for a beginner , it shows flaws the least . I'm also gonna bed-line the box , and the box rails . Hopefully in a month or so , I'll have completed stage 1 of this build , a 5" lifted 2wd baja style MJ . JIC your wondering , stage 2 will be the full 98 conversion , 4.0 transplant with 4WD . At this point , I may stroke the 4.0 and go long arms as well . Pretty sure this will be my last jeep build . It's my third , I still have all of them , so , I have collected enough , lol . Next project will be a another Chevelle I think , or a 78-81 Trans am/Z28 , always loved those cars , and I have had a few . That won't be for at least another yr unless a good deal falls in my lap . :D Link to comment Share on other sites More sharing options...
comancheap Posted May 1, 2011 Share Posted May 1, 2011 I really like how this is turning out. The white looks great on it! Link to comment Share on other sites More sharing options...
89Tonto Posted May 2, 2011 Share Posted May 2, 2011 Keep up the great work and write-ups. Add all the pictures you want. :idea: After your articles, I'll start on my build. :thumbsup: :clapping: Link to comment Share on other sites More sharing options...
NewfieMJ Posted May 6, 2011 Author Share Posted May 6, 2011 :fs1: I always do things twice it seems Ok , got it all done except the w/sheild . Had it on the road and it's not too bad considering my home done alignment Issues to report : That cursed valve on the heater core line leaks , and , pretty good too . The power steering has a leak and the box has play , no biggie , I have a ZJ box , fully adjusted , and ready to go , it's even painted all purdy The really good news is the leak in the head gasket on the pass side . I pressure washed everything down , went 5 miles and it's all down the side of the block :doh: On the bright side , I got a head gasket set with the engine when I bought it . Given my plan was to swap in the 4.0 and 98 harness and dash , seems like there's no better time than now . I'm pulling the XJ in the garage this weekend and removing the engine , trans , and case . The engine is junk , but the trans and case will be cleaned and painted , then laid aside . I may rebuild the 231 . I'll also be cleaning , painting , and refurbing the 98 intake and header in preparation . The XJ then goes back out before removing the wires . I have to bring the 91 MJ in to scoop the rebuilt 4.0 under the hood . Get it on the stand , and do a paint job , and some gaskets , and again , have it ready for the swap . After all that , pull the 2.5 from Dirty Harry , scrap the wiring and dash , clean , cut the firewall inserts and install for the conversion(going AC and ABS) route the wires , install the dash , drop in the new powertrain , install the HP 30 and convert the 8.25 to SUA , hope the 91's driveshafts work and figure out the fuel pump differences . Anyone know if the 91 tank and pump works ? I got me one of those :) Well that's the plan now , guess the wife won't get her truck this summer , maybe fall ? Yeah , I'll get pics of all the steps along the way :) Link to comment Share on other sites More sharing options...
