flracer Posted April 9, 2011 Share Posted April 9, 2011 My driver door has some slop in the hinges.Can i get parts to repair them or do i have to buy hinges?Any hints or places to get parts would be very helpful. Thanks,Richard Link to comment Share on other sites More sharing options...
bthomps875 Posted April 9, 2011 Share Posted April 9, 2011 wouldnt it be the same for an xj maybe go to your local junk yard? Link to comment Share on other sites More sharing options...
Eagle Posted April 9, 2011 Share Posted April 9, 2011 If the slop is in the hinges, you can buy replacement pins. If the slop is the hinge assembly moving relative to the door post -- it's a welded connection that's getting ready to fail, so get it fixed soon. Link to comment Share on other sites More sharing options...
maddzz1 Posted April 9, 2011 Share Posted April 9, 2011 There is a "fix" put out by Jeep to fix it if it is the hinge pulling away from the truck. Its like a reinforcement that is bolted on. Someone will post the part# Link to comment Share on other sites More sharing options...
kro10000 Posted April 9, 2011 Share Posted April 9, 2011 There is a "fix" put out by Jeep to fix it if it is the hinge pulling away from the truck. Its like a reinforcement that is bolted on. Someone will post the part# As far as I know it is discontinued, I wish it wasn't because my hinges are tweaked. I won't be too surprised when the door falls off, I just don't really know what to do about it. I think there is a write up about repairing them somewhere here, someone should definitely post it up. Link to comment Share on other sites More sharing options...
dave92cherokee Posted April 9, 2011 Share Posted April 9, 2011 http://www.naxja.org/forum/showthread.p ... nge+repair There's a thread on naxja and many more like it that shows different ways to fix it. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted April 9, 2011 Share Posted April 9, 2011 I did the repair as above, although I did weld around the hinge to give it some extra. IMO it is the best fix out there. You can see some pretty good shots of my repair here: viewtopic.php?f=7&t=17699 near the bottom of the first page. And the factory repair in the DIY: viewtopic.php?f=9&t=28641 really just a band aid because it doesn't address the lack of strength when fastening to the A-pillar with no structural backing behind it, which is really the problem in the first place. Link to comment Share on other sites More sharing options...
