webbjeepxj Posted April 6, 2011 Share Posted April 6, 2011 Will an MJ dana 30, ZJ dana 30, TJ dana 30 bolt into XJ's I figure MJs Dana 30s would ...... how about the rest? Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 6, 2011 Share Posted April 6, 2011 All of them will bolt in. But, the TJ will be a LP30 and the ZJ will be a LP30 with CV axles. Link to comment Share on other sites More sharing options...
Automan2164 Posted April 6, 2011 Share Posted April 6, 2011 All of them will bolt in. But, the TJ will be a LP30 and the ZJ will be a LP30 with CV axles. Not all ZJ's are CV. 242's could come with u-joints... I just swapped in a LP30 with u-joints and 3.73's into the ol' ZJ. Rob Link to comment Share on other sites More sharing options...
mvusse Posted April 6, 2011 Share Posted April 6, 2011 I've seen a number of ZJs with u joint axles, sometimes on one side, sometimes both. Small u joints, large, ABS, non ABS. It seems to not be uncommon to swap a u joint shaft in when a CV shaft goes out. Link to comment Share on other sites More sharing options...
