1987Comanche Posted April 5, 2011 Share Posted April 5, 2011 '91 4.0 HO, AW4, 2WD, column shift auto, grey bench, A/C, 165K on the clock. Was originally white but someone painted it purple!. Excellent body, however. Currently at a JY in Greenville, SC but will be crushed around 4/20/11. Link to comment Share on other sites More sharing options...
littlezeeker Posted April 7, 2011 Share Posted April 7, 2011 i beat with just a little bit of work that comanche will fire right up Link to comment Share on other sites More sharing options...
valis Posted April 7, 2011 Share Posted April 7, 2011 i beat with just a little bit of work Link to comment Share on other sites More sharing options...
JMO413 Posted May 25, 2019 Share Posted May 25, 2019 *B1 TRIM STYLE B1 - CLOTH && VINYL BENCH SEAT -SA CHARCOAL 166 Zone 66-Orlando 1AA U.S. Dealer Retail 3VQ Customer Preferred Discount 4HA Special Scheduling Condition I ALA SE Decor Group ALK Italia Package APA Monotone Paint BAF 130 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDN KWS STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RA8 Delete Radio SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Body Model TL61 Build Date 1/22/91 Link to comment Share on other sites More sharing options...
jdog Posted February 1, 2021 Share Posted February 1, 2021 Selling Dealer: DADE JEEP CHRYSLER Miami, FL Link to comment Share on other sites More sharing options...
