My 87 Manchee
Hey I am a noob to the MJ scene but not to Jeep thing. I have had a 04 Wrangler, a 95 Cherokee. Still have 2000 TJ and just picked up a 87 Comanche. It is a 4.0 auto. Not sure what lift is on it, but I plan on going with a different lift. It has no rust what so ever and just has a few dents. The engine is about ready to go in it, but I located another one just need to go get it. I will post progress pics as I go along. But this is how I brought it home.
i hope he never ran it in 4wd. that aint good for the t case
Why do you say that?
And nice truck :popcorn:
Brandon
tire size affects the gear ratio. since the different diameter tires will turn at different speeds, it would be like having your front and rear axle ratios mix matched.
Brandon
thus pretty much destroying your transfercase if you do it very much
