which d/30?
alright... so you can drive the truck with just taking the one peice of shaft out?
for me u-joints is a two-time job... cause like i said, i can't do them myself and i gotta drive the truck.. but we have extra D30 shafts so i can take my inner shaft out and leave the stub in, drive around til the u-joints are swapped, then pull the stub out and put the other stub+axle in.
but you're saying it won't hurt anythign to leave all the stuff from the disconnect-the diff in while driving right?
If you remove the outer shaft you can't mount a wheel to drive so no you can't. I didnt realize that is what you were asking the wheel mounts to the axle shaft as I explain before sorry for any confusion Hell I made be confused as well.
Cole
nah, on the d/30 you can pull the inner shaft and leave the outer stub shaft and drive. its a semi-floating axle if thats the correct term.
but i didnt know if you had to remove ALL the inside peices including the disconnect sleever and innermost shaft in order to drive.
If you are going to change u-joints why not swap to a solid passenger side shaft and call it good. You can replace the seal in the outer portion of the housing and not have to do the inside one and have no issues. This is what I di on Pong before I bent my first d-30.
As for the d-30 living with 35's. Before I upgraded to Yukon shafts I ate u-joints and stock shafts. I never went wheeling w/o at least 2 or 3 short shafts, abd a few rags and an outer. Just so I could get home. Once I upgraded i thought I was good, until I grenaded an Inner shaft at the splines :eek:
hey, after pullin the tranny out of the cherokee i didnt feel like doin an axle the same day. dad says ones gotta go before another can come so by by non disco
Wanna sell it??? :brows:
I am interested in another non disco D30. Your not too far from me.
Whats the time frame on your end? Would after the holidays work OK?
BTW,
With a sawsall its a QUICK thing to remove a D30 from a cherokee!!! :brows: :brows: :brows: It will take longer to jack it up and safely block it!!! Ask me how I know!!! jamminz.gif ;)
But seriously. I am interested in the axle.
CW
