kro10000 Posted March 31, 2011 Share Posted March 31, 2011 POOOOWWWWWEEEEEEERRRRRRR!!!!!!!!!!!!!!!!!! :eek: Haha, well I'd consider a GM Gen III motor, you can usually pick them up dirt cheap, make ridiculous power if you want, and get great economy when left reasonably stock. The 5.3 is probably what I would go with, mate it up somehow with an AX-15 and leave it stock in hopes of not destroying the trans, and give me what in all likelihood would be better than 4.0L MPGs. Also there are some aluminum 5.3s out there that will help drop the weight off an MJ's nose, and cool better. Of course if you want to go bigger, than the 6.0L engines (LQ4, LQ9) are out there, and are cheap. And if you want to spend money get any engine that starts with LS. Link to comment Share on other sites More sharing options...
cz777 Posted April 1, 2011 Share Posted April 1, 2011 :agree: yes on this one built a super 4 liter - use the best head etc easier etc ... Link to comment Share on other sites More sharing options...
Jomanche Posted April 2, 2011 Author Share Posted April 2, 2011 I am running 30x9.5 in tires right now with the stock gears 3.07s (Pete provided me with the gear ratio awhile ago, thanks again) Yes i did mean ZJ....in reference to the 4.0 engince that i have access to. I also have access to the rear / front end parts as well, 3.55 I think. The engine i have in it right now is the original engine but i know its getting a lil tired. I just want to be prepared when it goes. So if i could do something with the ZJ engine that runs good, i would like to utilize it. Should i just rebuild that one, maybe stroke it, if its going to work.... thats the big question. If i do rebuild it can i just drop it in and go without worrying about the computer stuff? Link to comment Share on other sites More sharing options...
streetjeep2.5 Posted April 2, 2011 Share Posted April 2, 2011 I've seen this before, but not sure where. Here? Anyway, here is an engine swap! Link to comment Share on other sites More sharing options...
91coMANche Posted April 2, 2011 Share Posted April 2, 2011 I have a ZJ engine in my 91. My engine is a 98. As long as you use the MJ intake manifold and motor mount brackets a ZJ long block will bolt right on in. Link to comment Share on other sites More sharing options...
Jomanche Posted April 2, 2011 Author Share Posted April 2, 2011 91coMANche..... and you didnt have to worry about any electronics? Link to comment Share on other sites More sharing options...
