SwayAwayComanche Posted March 18, 2011 Posted March 18, 2011 Hey guys, I finally got some cash saved up to purchase a trans and get rid of the puke goat,Anyways I have a few questions. My local junk yard has a ax-15 out of a 2wd 99 cherokee. will this work in my 4wd and if so what needs to be done?
jimoshel Posted March 18, 2011 Posted March 18, 2011 It won't work as is. The output shaft is different. It can be swapped but why bother? Get a AX15 for a 4WD.
SwayAwayComanche Posted March 18, 2011 Author Posted March 18, 2011 I found one, he's not sure if it's out of a 94 or 95...... and pry doesn't come with a master cylinder or line. what year did they change to external slave?
Naterenfo1 Posted March 19, 2011 Posted March 19, 2011 My 86 4wd MJ has an external slave on the top right of the bellhousing if that helps any :P
SwayAwayComanche Posted March 19, 2011 Author Posted March 19, 2011 Going to look at the trans today. not sure what he has all there. can the same hydro line be used and throw out bearing fork if it's an external slave setup? also what about the master cylinder? been searching can't seem to find this info.
SwayAwayComanche Posted March 24, 2011 Author Posted March 24, 2011 ok guys' I'm going to look at that trans this weekend now... so just for clarification i need all this stuff. please feel free to correct me.. -cross member -mount -slave -master cylinder -T/C linkage -hydro line -304 bearing -throwout bearing and fork Any of the ba/10 stuff work on the ax-15? like the line or clutch,pressure plate..ect
