KCsurfer420 Posted March 12, 2011 Share Posted March 12, 2011 So today i aquired a 98 xj sport that was in a front end colision . I bought it to convert the rest of my comanche to the 98 dash wiring and doors :clapping: . I picked it up for 800 dollars and it allready has a 4 1/2 lift and 33 the truck is a little bit dirty but i can clean it all up for the swap. Apon picking the xj up i was told by the kid that a drunk driver hit him (but i think that the drunk was behind the wheel and the rock wall was a victom in this case) but the front driverside is smashed, not bad as in i could replace the header pannel, and drivers fender and youd never tell it was wrecked its realy not that bad, however the airbags did deploy. he also told me that since the wreck the jeep won't start. I put it on the trailor and off i went. When i got home i put a new battery in it and tried to turn the key but all i got was a wire that decided to ground out coming from the ignition switch and burn up the wire. It dident eaven try to turn over or anything nither did the miles want to pop up on the gage cluster. I investigated the burnt wire and it seems to be a ground of some sort (black wire) it only burned for a few inches and luckily it dident butn any of the other wires. now i know that i am going to have to replace the wire and find out where it is shorting out before i go any further but i need a 98 xj FSM mainly for the wiring schematics, can any one help me out? now my next question is if the airbags deploy will that cut power to the rest of the truck or mainly how does the airbag system relate to the rest of the wiring? I'm going to go out there tomorow and pull the air bags out and find the sensor that set of the bags and see if i can get the system disconected to see if that helps my situation any, and try and breake down the wiring harness and sodet a new wire back in place of the burnt up one..... any help is greatly apreciated as allways. Link to comment Share on other sites More sharing options...
shelbyluvv Posted March 12, 2011 Share Posted March 12, 2011 Here is your manual. I buy them from him all the time. It does work. You may have to download a program to unzip it but then you will be good. http://cgi.ebay.com/1997-1998-1999-JEEP-CHEROKEE-XJ-SERVICE-REPAIR-MANUAL-/250656227133?pt=LH_DefaultDomain_0&hash=item3a5c467f3d Link to comment Share on other sites More sharing options...
Geonovast Posted March 12, 2011 Share Posted March 12, 2011 I have the 99 XJ FSM on my computer... Link to comment Share on other sites More sharing options...
KCsurfer420 Posted March 12, 2011 Author Share Posted March 12, 2011 Could i possibly get a copy from you so that i can trace that wire down? pm me and let me know.... Link to comment Share on other sites More sharing options...
NewfieMJ Posted March 12, 2011 Share Posted March 12, 2011 jeepslimited.com , free , every FSM you need , all jeeps Link to comment Share on other sites More sharing options...
87Warrior Posted March 13, 2011 Share Posted March 13, 2011 www.greatlakesxj.com also has FSMs available for download. Link to comment Share on other sites More sharing options...
KCsurfer420 Posted March 13, 2011 Author Share Posted March 13, 2011 thats exzactly what i needed thanks :thumbsup: Link to comment Share on other sites More sharing options...
