livesignal Posted December 14, 2006 Share Posted December 14, 2006 I am replacing some leaking injectors on my 88' Comanche 4.0L and am not sure how to remove those tiny little metal clips that hold the plastic wiring connector on the injector. They look easy to lose or break so I would like to get some advise on which tool works best and which direction to pry before I try removing them. Link to comment Share on other sites More sharing options...
comancheman Posted December 14, 2006 Share Posted December 14, 2006 i thought u had to pull the clips off when i did it but usually the harness lets go by just pulling connector side to side Link to comment Share on other sites More sharing options...
randimal Posted December 14, 2006 Share Posted December 14, 2006 They are open on one side. Just need to slide them the right way. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted December 14, 2006 Share Posted December 14, 2006 I used a small metal pic (similar to dental pic) to pry it off. It's partially open on one side, and the clip removes completely. Link to comment Share on other sites More sharing options...
KYMJ Posted December 14, 2006 Share Posted December 14, 2006 I used a pocket screwdriver. I had to replace a leaker the other day. Anybody used the injectors on e-bay for $99 for the set? I paid $70 for 1. Link to comment Share on other sites More sharing options...
livesignal Posted December 14, 2006 Author Share Posted December 14, 2006 Thanks everyone, I was able to get them removed using a dental pick I picked up at the local drug store. The way the pick is curved at the end and very sharp made it actually quite easy to insert it between the clip and plastic connector then twist the pick so it pulled the clip out the side a little. Then I just pushed that side of the clip forward some ( towards the engine ) and the connector pulled right off. Less than 5 minutes for all of them. Once the connector was unplugged I sprang the clips back into place on the connector to hold them so I don't lose them. BTW, the injectors I am installing I purchased used on ebay for $43 and are part numbers F4SE-A1B, 0280155700. These are the Ford Bosch Yellow Design III 19lb injectors and should work just fine. I'll let you know. Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 14, 2006 Share Posted December 14, 2006 yea i used the 200 somethin dollar 5-0 ones. dk, but HOs have MUCH cheaper injectors than us renix boys. :mad: Link to comment Share on other sites More sharing options...
