sinnaevd Posted December 10, 2006 Share Posted December 10, 2006 The teraflex conversion to switch to coil spring rear when my manche becomes obsolete for practical use i would love to switch it over anyone seen an MJ like that? difficult to do? Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 10, 2006 Share Posted December 10, 2006 Got a link to the kit? Quote Link to comment Share on other sites More sharing options...
sinnaevd Posted December 11, 2006 Author Share Posted December 11, 2006 http://www.dc4wd.com/tera.htm#xj there you go dirty its the grand up kit for xj's, you'll kind of have to scroll down to see what I'm talkin bout i don't know if i would go with that set up specifically, but it got my wheels turnin Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 11, 2006 Share Posted December 11, 2006 To make it fit a MJ would require rebuilding most of it. They aren't too forthcoming with the pictures, but I think it's a parrel lower and triangulated upper link setup. I would avoid these if you intend to have a lot of flex in the rear - as the axle will 'steer' itself, and it makes the vehicle very uncontrolable when attempting to climb with the suspension flexed out. But, that doesn't mean 4-linking/coiling the rear of a MJ is a bad idea. I've toyed with the idea, and plan to eventually. BrettM runs one I think (or is it a 3-link? ask him). Pingpong wants to do it. Quote Link to comment Share on other sites More sharing options...
feerocknok Posted December 11, 2006 Share Posted December 11, 2006 Sorry, but I don't think it'll fit MJ frame rails. I've been looking into linking the rear of mine in maybe a year or a lil less, but the gas tank is an issue right now. Quote Link to comment Share on other sites More sharing options...
sinnaevd Posted December 11, 2006 Author Share Posted December 11, 2006 yeah i don't think that kit will adapt to an MJ very nicely. But as diry put it, i am toying with the idea i think i would like to start fiddling with some suspensioin stuff this summer, after i toss a d30 up front i also toyed with the idea of making it a Baja truck (i don't think that the word I'm looking for but its the only one i could some up with) Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 11, 2006 Share Posted December 11, 2006 Pre-runner? I don't know of any deserts in Ontario... Quote Link to comment Share on other sites More sharing options...
Rokhound Posted December 11, 2006 Share Posted December 11, 2006 if you want some good reading pete listed these link for a 4 link it made my head hurt. http://www.pirate4x4.com/articles/tech/billavista/Links http://www.4wheeloffroad.com/techarticl ... index.html http://www.tellico4x4.com/index.php/cPath/2297 http://www.jeeps-offroad.com/misc-jeep- ... ators.html http://www.avalancheengineering.com/suspension.htm Quote Link to comment Share on other sites More sharing options...
sinnaevd Posted December 11, 2006 Author Share Posted December 11, 2006 there are none but i enjoy catching air sometimes. i woud like to be able to do it with the MJ, although i would more then likely destroy it. we had a sand rail out ot silver lake sand dunes and catchign air in that was awesome Quote Link to comment Share on other sites More sharing options...
pingpong Posted December 11, 2006 Share Posted December 11, 2006 More then likely I am going to do a double triangulated 4 link in the rear using air shocks or coilovers... I have to do some weighing of my rig to see if air shocks are an option. Expect to drop some serious coin if you want to do this. Just in joints your looking at 2-300 depending on what you use, thats not including steel and hardware, or the shocks for that matter Quote Link to comment Share on other sites More sharing options...
feerocknok Posted December 11, 2006 Share Posted December 11, 2006 I hope this becomes a thread flow, instead of a thread hijack, but: What do you guys think about the different heims that are out there for link building? Rod ends? And what are the thoughts of a heim on one end, bushing on the other. I'd like to plan out a system for my rear, and I think I'm understanding everything dandily, but the joints, and how wide apart to place the coils (haven't thought about the placement is the actual problem). Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 11, 2006 Share Posted December 11, 2006 The wider you place the coils the more 'stable' it'll seem. But, you're doing that by hurting flex. Although, typically it won't matter as you're going to hit your bumpstops first. So, you normally move them as far outwards as possible. Unless you have a 2KLB zuki and 220lb/in coils in the rear. Then you put them right next to each other - and jsut tip over every now and again. As far as the joints go, I personally believe in using matched joints on both ends of a link. Why? They're both going to travel the same number of degrees. If you're cheap, you could get away with running a bushing at one end and a proper joint at the other. And as far as the joints go, just get something that's greaseable/rebuildable and suits your plans and budget. It doesn't need to be hardcore HD if you're going to run 1/2-ton axle on a light vehicle like a MJ. Especially if you're building a 4-link which has 4 joints on each end to spread the load. I don't yet have a brand favorite, as I haven't got that far yet... Quote Link to comment Share on other sites More sharing options...
feerocknok Posted December 11, 2006 Share Posted December 11, 2006 I had the bushing on one end in mind to provide stability, but I understand what you're saying about the joints travelling at equal degrees. Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 11, 2006 Share Posted December 11, 2006 Your link ends shouldn't be providing stability. That's for the actual suspension geometry OR for an anti-sway bar (like an anti-rock...). Quote Link to comment Share on other sites More sharing options...
feerocknok Posted December 11, 2006 Share Posted December 11, 2006 Your link ends shouldn't be providing stability. That's for the actual suspension geometry OR for an anti-sway bar (like an anti-rock...). :oops: true. Quote Link to comment Share on other sites More sharing options...
sinnaevd Posted December 11, 2006 Author Share Posted December 11, 2006 definately need to read into it a LOT more is it safe to be building it myself?/ still safe for the road if i chose to take in on a trip? ( i can't see why it wouldnt be but i am very new to the concept as well) Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 11, 2006 Share Posted December 11, 2006 I'd want to be very confident in my fab skills before I did it... Having a link/bushing/bracket fail on the street coul be bad. Properly setup it'll drive fine though. Quote Link to comment Share on other sites More sharing options...
sinnaevd Posted December 12, 2006 Author Share Posted December 12, 2006 yeah i think i will fiddle with some smaller stuff befor i do that i want to get an accurate CAD of the frame drawn up do i can tinker with geometry and stuff with it first i think i should go with a bolt on kit before a mess around wtih any of that stuff just having a hard time determining where i want to start modding at Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
