1J7FJ36SML550609
J B Cuz
1991 MJ short box "Ditto" 160k A work in progress
Daily driver in St Paul MN
4.0l, AW4,NP231/with slip yoke eliminator,
Front axle: Dana 30 ARB with 4.88 soon to be changed to 4.10 I want better mileage
Sway bar: Sway Loc remote air disconect
Rear axle: Dana 44 Power trax locker 4.88/4.10 disc brakes
Engine: stock with york style on board air
Suspension: AiRock 6" kit on front TNT long arms and Rear a custom 4 link with stinger
Front bumper: Iron Scorpion welded by me with Warn 8000 winch and X line rope
rear bumper: Custom made by me with wrap around protection
Nerf bars: custom made by me
Tires and rims: BFG mud terrains 255/85R16 on Alcoa rims (33" x 9.5")
Bed cover: by Truxedo, Mac,s tie downs inside, Lite Spots and 12v plug in for Engel cooler
  • 8 years later...
VIN 1J7FJ36S2ML550609
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT
-Y6 DARK SAND
174 Zone 74-Denver
1AA U.S. Dealer Retail
3V2 Customer Preferred Discount
ADH Heavy Duty Electrical Group
ADL Skid Plate Group
AHL Heavy Duty Insulation Group
ALM Longhorn Southfork Package
APA Monotone Paint
ARL 300 Premium Group
BAF 130 Amp Alternator
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEC Front Left Side Sliding Window
GFD Rear Sliding Window
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
HGD Deluxe Insulation Group
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K27 Do Not Use
K2B STRIPE/BADGE/MOLDING/COLOR
K3G STRIPE/BADGE/MOLDING/COLOR
KKS STRIPE/BADGE/MOLDING/COLOR
KWS STRIPE/BADGE/MOLDING/COLOR
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAF High Altitude Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PG5 Hunter Green Metallic
QG5 Hunter Green Metallic Clear Coat
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
TZH Michelin Brand Tires
WJN 15" Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z83 Right Front Spring Group XII
Body Model JL61
Build date 11/7/90
  • 1 year later...
