I've change everything to make it start
the starter
the relay
the wires
the ignition switch
the cpu
fuze links are good
the starter make noise like the selenoid engages but won't crank the engine
plz I need ideas or sugestions
I know this is gonna sound stupid, but have you had the battery tested? I mean from a parts store? It could be that your battery is worn down, or even possible that it doesn't have enough cold cranking amps to turn the motor over. Could even have bad battery cables or cable ends. If their not tight on the battery it won't start. Might also be that the new starter is bad. Test it off the truck and see if its working properly. This is just my first thought. I've had these things happen to me.
Are you sure the engine isn't seized? Pull the spark plugs and see if you can turn the engine by hand with a breaker bar on the nut at the front of the crankshaft.
found it
it seems that my starter is not grounding properly
when we retested on the bench we had to ground the selenoid body with the ground prong
if not the selenoid would push the gear out but wouldn't turn the starter
thanks for the answers
that will be one for the years to come
I Hate electrical problems, but it seems to be the culprit alot. Its usually a good idea to check wiring first. Plus its a cheap fix, my favorite kind :cheers:
the damn starter would not stop giving me probs so I went and bought a new one
fired right up
so the prob wasn't the electrical but the starter itself
thanks all for the replys
Dominic
