Rubicon Express???
use the xj long arm kit and spring over your rear, IIRC you have to spring over the read with the 5.5 kit ne way
Rubicon Express makes a solid kit that you can trust. :thumbsup:
shop around as well, there are some smaller companies i have found by searching that SEEM to have decent kits as well
the RE drop bracket kit is really good, and WAY better than rough country crap
however I strongly disagree with the RE longarm recommendation, it's a terrible design. if you want long-arms, get TnT, Full Traction or maybe Rock Krawler.
http://www.tntcustoms.com
i will be going with the RE kit... my brother has had his RE XJ4.5" for 1 1/2 years now and it rides GREAT,m wheels GREAT, and is just all around GREAT.
he hasnt had a single suspension or geometry related problem since his lift.
(before that was a different story as a hydroplaning accident ruined his ca's and all that.)
Just curious where the problem is. Is it the path in which the axle cycles, or does it want to bind, or?
i don't know of any problems but he might know of some.
the tnt kit just has a LOT more clearance due to the bend in the LCA.
:rotfl2: They actually work rather well..A friend of mine made trac bars out of some on his f250 and no problems..However I have already purchased 24' of 1.5" tubing and the bungs to do crossover steering and build me some long arms..I may step up to 2" tube for the long arm though..
