MCF90 Posted January 25, 2011 Posted January 25, 2011 Hey guys, Just a quick question, I noticed the driver's side front camber is off a bit (bottom of the wheels is kicked out farther than the top) as compared to the passenger side. I checked the hub, it seems to be in good shape. Is this as simple as taking it to a shop and having it aligned? Thanks guys! Matt
HOrnbrod Posted January 25, 2011 Posted January 25, 2011 Camber angle is fixed by the ball joints and can not be adjusted unless adjustable ball joints are installed.
deziped Posted January 26, 2011 Posted January 26, 2011 Maybe you got a bent axle tube. Have you been jumping off hills again?
MCF90 Posted January 26, 2011 Author Posted January 26, 2011 Maybe you got a bent axle tube. Have you been jumping off hills again? HA! No, no jumping, lol. Matt
MCF90 Posted January 26, 2011 Author Posted January 26, 2011 Any recomendations as to brand of ball joints to use/where to get them? Thanks guys! Matt
Dougster123 Posted May 13, 2011 Posted May 13, 2011 Hey guys, Just a quick question, I noticed the driver's side front camber is off a bit (bottom of the wheels is kicked out farther than the top) as compared to the passenger side. I checked the hub, it seems to be in good shape. Is this as simple as taking it to a shop and having it aligned? Thanks guys! Matt I have this same problem, only on both sides. Haven't picked a shop to check alignment yet cause they all start off talking about installing adjustable ball-joints as a fix - while I want to understand what is causing this. I'll keep researching past forms before posting a new thread on this. MCF90, any updates?
MCF90 Posted May 17, 2011 Author Posted May 17, 2011 Nope, still need to get it to an alignment shop, just haven't had a ton of time lately. Matt
