Puddles on my floor.
Good idea! I had my buddy hold a hose over my truck while I was in it, and it was coming in on the bottom front curve of the driver door. I replaced the secondary seals in hopes it would help, and it did a little bit, but I'm still getting some water in there. I'll try to give that powder trick a go. Thanks. :thumbsup:
Mine was leaking in a few spots, but I was able to figure out where it was leaking. I put a bead of silicone around the rear window, and I took off the side vents and siliconed those shut. I also ran some silicone on the weatherstrip on both door frames. I have yet to see a noticeable amount of water. comanche.gif
