91coMANche Posted January 14, 2011 Share Posted January 14, 2011 Can a 2-3" lift soa be accomplished without losing load capacity? Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2011 Share Posted January 14, 2011 why? Link to comment Share on other sites More sharing options...
91coMANche Posted January 14, 2011 Author Share Posted January 14, 2011 During my axle swap I'll be rewelding perches anyway. Link to comment Share on other sites More sharing options...
mkbruin Posted January 14, 2011 Share Posted January 14, 2011 hit or miss with junkyard packs. Some say a j-series or waggy rear pack will get you close, others say a toyota pack or XJ pack with an MJ main... Any way you go (well, maybe not waggy rear) you will have less support on the mj main and will experience severe sagging or braking/bending of the main. Personally, I would go AAL or new HC packs. Its just not worth spending almost as much for used junk. Think of it this way. take where you are now. Add 3" for axle tube diameter alone. Add another 1/2 to 1" for perches. add another 1.5" for the thickness of the pack. If you plan to keep the factory pack, you will not get down to ~3.5". Just won't happen. Link to comment Share on other sites More sharing options...
Geonovast Posted January 14, 2011 Share Posted January 14, 2011 Link to comment Share on other sites More sharing options...
