87 comanche custom
  • Replies 72
Thanks man I agree, for the next coat I'd like to do the spraying myself and cover the bedrails.
oh and not sure if anyone needs to know this I had quite a bit left over after I finished rolling the tailgate, so if anyone has a 6 ft bed that little package easily does the job.
I noticed the brake pedal was feeling kinda spongy when I pushed it down all the way.
so I got under the truck and had a look at the bleeder screws, they were covered in dirt and rust.
after about twenty minutes I had the rust and dirt scrubbed off and all the screws were moving in and out nicely.
So I then bled all the brakes and now I barely have to put the weight of my foot on the pedal to stop the vehicle :thumbsup:
BUT the fluid in the reservoir had gone black! like almost tar black. but when I was bleeding the fluid coming out of the lines was clear?
So i'm kinda scared that the brakes are going to fail me.... I'm going to start looking for replacement parts asap.
Have a brake flush done to replace the fluid, which has probably never been changed!!
Another Canadian EH :Canadaflag:
Great job so far!!!! Keep it up :wrench:
Yeah I'm looking forward to flushing that crap out.
I've never changed it since when I bought the truck the guy told me that he replaced the brakes,
I assumed that meant the fluid too!
this thread should be getting a lot more interesting as I'm starting work beginning next week.
And that means more dollars to drop on the Manche!
So I didnt want to take the axle cover off to read the numbers for the gear ratio,
So I sat under the truck and scrubbed the axle tube and found the BOM.
Went on the website and it says I have 4.11 gear ratio. :thumbsup: good to know.
http://www2.dana.com/expertforms/deabill.aspx
My number was 605324-7 E
the axle was listed under XJ pickup
I got the business cards, magnet and Canadian flag comanche sticker in the mail today!
Thank you Peter! I'll be getting my donation out to you in a few short days hopefully.
Now I've gotta figure out where to put these guys..
  • 1 month later...
so... it's been a while since I've done anything to the truck,
I went to the junkyard after reading madxj's write up about the door seals, picked up two new(er) seals off a 99 xj.
now when I close my doors it actually sounds like a bassy thump instead of a slam.
Also on Island4x4.com theres a Dana 30 for free!
I called the guy so I can pick it up today and he says it was out of a four banger, (fingers crossed on the right ratio!)
Damn! I picked up the axle and it has a 3.07 gear ratio
I'm gonna start looking around for a new set of gears and search up how to put it all together.
I also took off the brake calipers and opened up the CAD thing. It's still intact and functional just needs hoses.
  • 1 month later...
So I took the Comanche, filled up the bed with yard trimmings and parked on a hill.
stomped on the parking brake and "SNAP!" the front cable breaks.... great!
I've wanted to replace that cable for a long time and now I HAVE to.
They didn't have it at Lordco in Duncan, So I ordered it in for tomorrow.
I also got off my @$$ and bought a new rear pinion seal for the dirty five.
VERY VERY easy job to do.
I think the guy who installed the seal before used the wrong sealant on the outside edge, causing the leak.
and the older seal looked smaller and didnt have the inside rubber seal making me think it was the wrong part.
I have bought my oil pan gasket kit and installed the brake cable.
must have been a dud because the first time I go to use it POP! the end that clips into the brake pedal slid up! FUNK!
So I called up lordco and they re-ordered it saying raybestos usually never fails like that.
at least they didn't charge me anything.
Also doing a lot of searches on dropping the oil pan and taking out the oil pump, I've never done it before so I feel I've gotta learn more than whats sitting in the haynes manual. :typing:
so have you had it in 4 -wheel yet? forget about the hoses, just take the cover off, slip the collar ofer to the "in" position, and put the cover back on upside-down. that way you will never have to worry about it again.
:fs1: :fs1: :fs1: :fs1: :fs1:
WOW I found a hefty chunk of metal in my oil pan. :fs2:
and some sort or clip and shavings.......Waaaaah! :???:
I'm surprised the dang thing still runs.
I looked under when the oil pan was removed and in between cylinders 1 and 2 I could see where the chunk was torn out. (I know, I don't know any technical engine words so that will have to do)
I'm gonna take some pictures and post them here and the tech forum to get an idea of what I'm replacing, OR
If I should just run it into the ground and buy a I6 like everyone else on this damned four banger hatin island.
I'm lovin' my 4-banger (but admittedly it's not much of a powerhouse). - i can wheel all day long in the coast mountains, then drive to work everyday for a week - on $20. worth of gas. -who wouldnt like that? -its like driving a really big smart-car, lol.
