jimoshel Posted December 29, 2010 Posted December 29, 2010 If you have a burning question needing a quick, informative response, then try the search function before posting on the forum. Saves time and keeps you from looking like a jerk. Also keeps Pat from getting annoyed at ya. I'm getting ready to swap a set of axles from a 2001 Cherokee to a '86 MJ and was wondering whether to keep the ABS function. Started to post the Q in the tech section but thought about the Search function. Typed 'ABS' in the box and got 3 replies. Told me everything I wanted and needed to know. :smart: PS. The reason I wanted to swap was for the heavier U joints in front and to stop the howling and clunking from the rear. And I am keeping the ABS function.
shelbyluvv Posted December 29, 2010 Posted December 29, 2010 You do know that front 30 is a low pinion right?
jimoshel Posted December 29, 2010 Author Posted December 29, 2010 Give it a couple drinks. It'l be OK.
JeepcoMJ Posted December 30, 2010 Posted December 30, 2010 If you have a burning question needing a quick, informative response, then try the search function before posting on the forum. Saves time and keeps you from looking like a jerk. Also keeps Pat from getting annoyed at ya. I'm getting ready to swap a set of axles from a 2001 Cherokee to a '86 MJ and was wondering whether to keep the ABS function. Started to post the Q in the tech section but thought about the Search function. Typed 'ABS' in the box and got 3 replies. Told me everything I wanted and needed to know. :smart: PS. The reason I wanted to swap was for the heavier U joints in front and to stop the howling and clunking from the rear. And I am keeping the ABS function. :rotfl2:
xjrev10 Posted December 30, 2010 Posted December 30, 2010 You do know that front 30 is a low pinion right? for a stocker it don't matter. tjs never came with HP30 from that era
