MJRemi Posted December 28, 2010 Share Posted December 28, 2010 My 88 4.0 5spd 2wd can't seem to pass smog. The tech says he replaced the O2 sensor and now it's running super rich. He tested the temp sensor and it's fine. I replaced the MAP about 2 weeks ago. He says he thinks it's going to be a bad computer. Since he has my truck for at least another day, can you guys think of any other causes for the rich fuel? Is the computer something I can pull from a JY or should I buy a new one? This is getting frustrating and expensive. Link to comment Share on other sites More sharing options...
Mongo Posted December 28, 2010 Share Posted December 28, 2010 can't say for sure, but usually a rich fuel mixture is due to a temperature sensor, but not sure that our computer monitors that. I will have to dig in the factory manual later on this evening to see. Other thing to check fuel pressure for a leaking fuel injector. I will see if there is anything when I get done with my honeydo and post up. Link to comment Share on other sites More sharing options...
alleydog Posted December 30, 2010 Share Posted December 30, 2010 Maybe the fuel pressure regulator is leaking. pull the vacuum hose off it an see if theres fuel in it. Link to comment Share on other sites More sharing options...
shelbyluvv Posted December 30, 2010 Share Posted December 30, 2010 Check the EGR valve too. If it is sticking it will make it run like crap. Link to comment Share on other sites More sharing options...
MJRemi Posted December 30, 2010 Author Share Posted December 30, 2010 Hopefully I will get my truck back from the shop on Thursday. The owner/mechanic seems to know what to test but i don't think the MJ is a priority for him. I really need to learn how to do this work for myself. The labor and mark-up costs are killing me. I'll be glad to get this smogged so I can move on to the transmission swap. Link to comment Share on other sites More sharing options...
