maddzz1 Posted December 28, 2010 Share Posted December 28, 2010 Slid on ice tonight and there appears to a problem with the abs on my 97 blazer, 4.3 auto I can feel the pedal vibrating under my foot and it makes a strange noise. Everything seems to lock up. Pedal does not go to the floor, but gets rock hard. Any of you chevy techs got any ideas. No ABS light, tho I have read about alot of ABS complaints on these trucks. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 28, 2010 Share Posted December 28, 2010 do the tires lock up. if not thats exactly what my dads 99 s 10 did until a certain fuse and bulb disappeared..... 8) best upgrade we ever did Link to comment Share on other sites More sharing options...
maddzz1 Posted December 28, 2010 Author Share Posted December 28, 2010 I think so. I may be removing the fuse too, and only putting back in for inspections. I have read it may be the ABS sensor on the hub. They have to be removed, cleaned, and then a piece filed down before reinstalling. Something about air pulse readings or something like that. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 28, 2010 Share Posted December 28, 2010 best thing to do is disable them. if you don't youll be buying a new abs sensor every 6 months or so. in our truck we couldnt keep those sensors working no matter what we did Link to comment Share on other sites More sharing options...
WBKrazy Posted December 28, 2010 Share Posted December 28, 2010 yeah jim, proper procedure to fix GM ABS is 1. remove the 2 fuses (one underhood, one underdash) and if you can't stand to see the abs light on, 2. remove the gauge cluster and pull the bulb out. it's most likely the abs module... when they go bad it won't turn the light on, but will make trying to stop very fun... michelle's blazer needs one too, but i followed the above procedure and now everything is good again :rotf: Link to comment Share on other sites More sharing options...
valis Posted December 28, 2010 Share Posted December 28, 2010 I can feel the pedal vibrating under my foot and it makes a strange noise. Everything seems to lock up. Pedal does not go to the floor, but gets rock hard. Any of you chevy techs got any ideas. No ABS light, tho I have read about alot of ABS complaints on these trucks. This is exactly how my Dad's '98 Blazer reacts when the ABS kicks on. No problems with the ABS that we know of, just the way its always been. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 28, 2010 Share Posted December 28, 2010 simply put. s10/blazer abs sucks Link to comment Share on other sites More sharing options...
valis Posted December 28, 2010 Share Posted December 28, 2010 simply put. s10/blazer abs sucks Eh, it's actually not bad when compared to some of the ABS pumps/modules that came out in the late 80's and early 90's when it really began gaining popularity. The system on my '91 3000GT is laughably bad and much much worse than the Blazer and S-10. I've actually had the ABS kick on in my Dad's Blazer and I was able to steer the vehicle to safety so I can't give it too many complaints. The system in my '91 3000GT honestly is more dangerous than safe, even when it's working 100%. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 28, 2010 Share Posted December 28, 2010 simply put. s10/blazer abs sucks Eh, it's actually not bad when compared to some of the ABS pumps/modules that came out in the late 80's and early 90's when it really began gaining popularity. The system on my '91 3000GT is laughably bad and much much worse than the Blazer and S-10. I've actually had the ABS kick on in my Dad's Blazer and I was able to steer the vehicle to safety so I can't give it too many complaints. The system in my '91 3000GT honestly is more dangerous than safe, even when it's working 100%. it works okay but i find your always changing sensors or modules. it seems to break really easy. Link to comment Share on other sites More sharing options...
maddzz1 Posted December 29, 2010 Author Share Posted December 29, 2010 I can feel the pedal vibrating under my foot and it makes a strange noise. Everything seems to lock up. Pedal does not go to the floor, but gets rock hard. Any of you chevy techs got any ideas. No ABS light, tho I have read about alot of ABS complaints on these trucks. This is exactly how my Dad's '98 Blazer reacts when the ABS kicks on. No problems with the ABS that we know of, just the way its always been. I think your misunderstanding what I'm saying. This is EXTREMELY DANGEROUS. Everything locks up. You cannot steer or do anything which is even worse because it is doing this on icy roads. In 2 days I have went thru a red light and just missed hitting someone and my wife went thru a stop sign and only avoided an accident because the other car saw her and stopped. Link to comment Share on other sites More sharing options...
valis Posted December 29, 2010 Share Posted December 29, 2010 I can feel the pedal vibrating under my foot and it makes a strange noise. Everything seems to lock up. Pedal does not go to the floor, but gets rock hard. Any of you chevy techs got any ideas. No ABS light, tho I have read about alot of ABS complaints on these trucks. This is exactly how my Dad's '98 Blazer reacts when the ABS kicks on. No problems with the ABS that we know of, just the way its always been. I think your misunderstanding what I'm saying. This is EXTREMELY DANGEROUS. Everything locks up. You cannot steer or do anything which is even worse because it is doing this on icy roads. In 2 days I have went thru a red light and just missed hitting someone and my wife went thru a stop sign and only avoided an accident because the other car saw her and stopped. Yea, then you've got a definite problem with your system, even if the ABS light is not on - maybe the bulb is bad? However, when the ABS system is not functioning, you normally won't have the ABS pump kick on when you try to brake, and with the vibration in the pedal and the weird sound you described, the ABS pump definitely sounds like it's coming on. The wheels should never lock up. It's an anti-lock braking system, after all... Link to comment Share on other sites More sharing options...
maddzz1 Posted December 29, 2010 Author Share Posted December 29, 2010 Yeah, after doing some resarch there is a TSB on the ABS system. It should have been a recall since it is a safety issue. Link to comment Share on other sites More sharing options...
comanche12 Posted December 29, 2010 Share Posted December 29, 2010 no pronblem with my dad's 04 blazer v6 RWD i have same problem with my 07 impreza. its tend active too early while I'm gentle press the pedal. so i removed the ABS fuse. its brake alot better on ice and snow :thumbsup: Link to comment Share on other sites More sharing options...
mythreesons Posted December 31, 2010 Share Posted December 31, 2010 I think your misunderstanding what I'm saying. This is EXTREMELY DANGEROUS. Everything locks up. You cannot steer or do anything which is even worse because it is doing this on icy roads. In 2 days I have went thru a red light and just missed hitting someone and my wife went thru a stop sign and only avoided an accident because the other car saw her and stopped. Its called taking your foot off the brake pedal, pumping it back and forth and steering the car where you need it to go. Thats why they put ABS on cars because people would freak out and just lock the tires up and wreck all the time, when its as simple as taking your foot off the brake and you can steer again. :doh: The above is from one of my knothead son's who was poking around while I was busy. :doh: Link to comment Share on other sites More sharing options...
maddzz1 Posted December 31, 2010 Author Share Posted December 31, 2010 I think your misunderstanding what I'm saying. This is EXTREMELY DANGEROUS. Everything locks up. You cannot steer or do anything which is even worse because it is doing this on icy roads. In 2 days I have went thru a red light and just missed hitting someone and my wife went thru a stop sign and only avoided an accident because the other car saw her and stopped. Its called taking your foot off the brake pedal, pumping it back and forth and steering the car where you need it to go. Thats why they put ABS on cars because people would freak out and just lock the tires up and wreck all the time, when its as simple as taking your foot off the brake and you can steer again. :doh: The above is from one of my knothead son's who was poking around while I was busy. :doh: I hope so. I was gonna say, maybe you need to call chevy and tell them they released a tsb for no reason. Link to comment Share on other sites More sharing options...
