pederl Posted December 13, 2010 Share Posted December 13, 2010 Link to comment Share on other sites More sharing options...
jimmy21669 Posted December 13, 2010 Share Posted December 13, 2010 I don't think they go to anything.... Link to comment Share on other sites More sharing options...
91coMANche Posted December 13, 2010 Share Posted December 13, 2010 The last two look awfully similar to what attaches to the air conditioning compressor. Is your air conditioning working? Link to comment Share on other sites More sharing options...
pederl Posted December 13, 2010 Author Share Posted December 13, 2010 AC works. The truck is very hard to start, and when it does it runs very rough, I have to give it gas or it dies. If I spray starting fluid into the intake it runs like a champ. I have replaced: Throttle position sensor Idle speed motor Knock sensor Spark plugs, wires, distributor and cap Fuel pump and fuel filter Battery Link to comment Share on other sites More sharing options...
91coMANche Posted December 13, 2010 Share Posted December 13, 2010 The symptoms you mention make me think you got a dud idle air controller or you have a small vacuum leak. Could you put your vehicle specifics in your profile so we can better help you? Link to comment Share on other sites More sharing options...
tallon2064 Posted December 14, 2010 Share Posted December 14, 2010 The one in the first pic may be for the under hood light. Looks kinda like the wire in mine. Link to comment Share on other sites More sharing options...
mule13 Posted December 14, 2010 Share Posted December 14, 2010 did you clean your throttle body when you replaced all that stuff? that and like someoen said a vacuum leak somewhere Link to comment Share on other sites More sharing options...
pederl Posted December 14, 2010 Author Share Posted December 14, 2010 It is a 1989 4.0 base model. Link to comment Share on other sites More sharing options...
pederl Posted December 14, 2010 Author Share Posted December 14, 2010 In the 3rd pick you see those yellow connectors, if I connect those to a computer would it be able to tell me anything, or was a 1989 too early? Link to comment Share on other sites More sharing options...
airspeed Posted December 14, 2010 Share Posted December 14, 2010 The first wire is for the under hood light option. The second and third wires look like they should power the shift light. Will they plug together? Link to comment Share on other sites More sharing options...
Akula69 Posted December 14, 2010 Share Posted December 14, 2010 First one is the positive lead under hood light. Second one is the cruise control subharness (provides pulse rate). The third is one I haven't seen except on the sub-harness that comes up from the transmission (not AW4). I have never seen a corresponding connector for it. Link to comment Share on other sites More sharing options...
