Cheech Posted December 11, 2010 Share Posted December 11, 2010 The front axle disconnects fine during warm weather, but when its cold outside the axle will not disconnect when you go back into 2wd. Accordingly, the indicator light stays on as well. Is this a vacuum issue, or is something just sticky? Link to comment Share on other sites More sharing options...
Mike Stone Posted December 11, 2010 Share Posted December 11, 2010 try going very slow in reverse. that works for my 86. By the way have you had any ignition problems? I lost spark and can't get it back. my MJ is a 1986 2.5 4x4 5 speed Link to comment Share on other sites More sharing options...
mnkyboy Posted December 11, 2010 Share Posted December 11, 2010 I would disable the disconnect, that way as soon as you pull the lever it engages the four wheel drive and the second you put the lever down it will disengage. No more waiting for it,it will also make the system more reliable since all the vacuum crap will be gone. Link to comment Share on other sites More sharing options...
pamike Posted December 11, 2010 Share Posted December 11, 2010 I would disable the disconnect, that way as soon as you pull the lever it engages the four wheel drive and the second you put the lever down it will disengage. No more waiting for it,it will also make the system more reliable since all the vacuum crap will be gone. i did this also and i'm glad i did. works great. my vac hoses kept falling off and my 4x4 didn't work. Link to comment Share on other sites More sharing options...
mvusse Posted December 11, 2010 Share Posted December 11, 2010 Same here. Lost my vacuum hoses three times during two trips off road. After that I went to a single piece shaft and pulled all the disconnect crap off the axle. Link to comment Share on other sites More sharing options...
Myron Posted December 12, 2010 Share Posted December 12, 2010 Same here. Lost my vacuum hoses three times during two trips off road. After that I went to a single piece shaft and pulled all the disconnect crap off the axle. :agree: Less likely to break an axle, and easier to replace when you do break it. Link to comment Share on other sites More sharing options...
