interior pillar light Q.
I just copied this from the Bulb Replacement for the Interior Dome Light Thread...
The dome lights in our trucks really are terrible IMO. I did fix mine up though doing both the things mentioned and they work really well now! First, I cleaned up the contacts. If the WD40 isn't working, try a pencil eraser. Pencil erasers sometimes work wonders are electrical contacts. Second, I soldered the wire that btm24 is referring to. By doing this it allows the lens to sit level when operating while the door is open. All you have to do is solder a small piece of wire between the contact where the roller on the lens sits to the top contact. If that is still a bit confusing, here's a couple pics.
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
