specialkeay Posted November 21, 2010 Posted November 21, 2010 Is touch n "foam a good idea" or a bad idea?
kyleag89 Posted November 21, 2010 Posted November 21, 2010 Spray foam in a can? That is bad because it holds moisture and will rot anything out that it touches.
specialkeay Posted August 20, 2013 Author Posted August 20, 2013 Do they make replacement rocker panels for jeeps?
rmoore1031 Posted August 20, 2013 Posted August 20, 2013 ^ Look on rockauto. A lot of Jeep people use 2x4 or 2x6 metal instead of stock replacement.
87Warrior Posted August 21, 2013 Posted August 21, 2013 If you want a stock like fit and finish: http://www.autopartsnetwork.com/1992-jeep-comanche-rocker-panel/avao_EbsOmWL4
92tanMJ Posted August 23, 2013 Posted August 23, 2013 I used 2x4 on mine and I sure wish I had gone with 2x6
