mule13 Posted November 21, 2010 Posted November 21, 2010 anyone have a link to a vacuum diagram for the vacuum that operates the heat? my heat works but only on defrost.I'm thinking a vacuum line is off somewhere? theres so many vacuum lines i don't know which is what without something to direct me
mvusse Posted November 21, 2010 Posted November 21, 2010 Defrost is where it defaults to when there is no vacuum. There are only two vacuum hoses running through the firewall to under the dashboard. One supplies vacuum to the controls, the other goes from the controls to the diverter valve under the hood. This valve serves no actual function other than being another part to break. Your problem is somewhere in the vacuum line that goes from the main vacuum feed under the hood through the firewall to the controls. If it got disconnected or broke under the hood it's an easy fix. If not you may have to tear your dash apart.
Pete M Posted November 22, 2010 Posted November 22, 2010 the most common leak area that seems to cause that is the vacuum reservoir located in the bumper towards the pass side.
mule13 Posted November 22, 2010 Author Posted November 22, 2010 yea id like to relocate that caister to somewhere under the hood, not sa far away from tthe vacuum source.seems like a strange place to put it, right in front of the tire like that.gonna look for a new canister before i do though
dasbulliwagen Posted November 22, 2010 Posted November 22, 2010 The vac lines youre looking for go through the firewall right with the heater hoses at the heater core tubes. Just follow the one to the heater control valve, and the other should lead you to the canister, and from the canister back to the manifold. I fised this on my bosses truck recently, all hoses looked fine, but still wasnt getting good vac, so I pulled all the hoses and lines out to inspect them and found a bad spot in the hard line where it goes through the rad core support. so I fixed the bad spot, and shoved the vac canister into a nice spot in the engine bay where it can be serviced easily. Good Luck.
