kbusch18 Posted November 20, 2010 Share Posted November 20, 2010 hey just wondering what interior parts work for say an 87 Comanche like i know other Comanches do but would other Cherokees fit and if so roughly what years i am looking for door panels,dash specifically under steering wheel Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 20, 2010 Share Posted November 20, 2010 Start hitting the yards. There were several upscale trim interiors used throughout the MJ/XJ years; Laredo, Country, leather heated seats, etc. Seats from any XJ up to 1993 are a direct bolt-in for the MJs, and door/dash panels and parts up to 1996 can be used. I preferred the Laredo interior and swapped in the seats from a 2-door XJ Laredo and all the rest 4-door XJ Laredo. Link to comment Share on other sites More sharing options...
kbusch18 Posted November 20, 2010 Author Share Posted November 20, 2010 thanks man great help in the yard tomorrow ha Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 20, 2010 Share Posted November 20, 2010 Anything to help Kyle Busch. Can you send me your autograph? :cheers: Link to comment Share on other sites More sharing options...
kbusch18 Posted November 20, 2010 Author Share Posted November 20, 2010 ha i would have a hard tome doing that seeing that i am a Michigan fan ha Link to comment Share on other sites More sharing options...
Akula69 Posted November 20, 2010 Share Posted November 20, 2010 ha i would have a hard tome doing that seeing that i am a Michigan fan ha :rotf: Yeah, well he probly likes me even less since Alabama came to visit LSU. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 20, 2010 Share Posted November 20, 2010 ha i would have a hard tome doing that seeing that i am a Michigan fan ha :rotf: Yeah, well he probly likes me even less since Alabama came to visit LSU. THIS Kyle Busch: And hey Jake - we still have Auburn. :yes: Link to comment Share on other sites More sharing options...
glundblad Posted November 21, 2010 Share Posted November 21, 2010 Hey Don, Does your truck ALWAYS look like that? Have you ever considered driving it periodically? :rotf: Link to comment Share on other sites More sharing options...
tbrand Posted November 21, 2010 Share Posted November 21, 2010 Seats from any XJ up to 1993 are a direct bolt-in for the MJs, and door/dash panels and parts up to 1996 can be used. Wait, now I'm confused. I thought any XJ seats required some bracket modification - perhaps I misread before? Link to comment Share on other sites More sharing options...
glundblad Posted November 21, 2010 Share Posted November 21, 2010 Seats from any XJ up to 1993 are a direct bolt-in for the MJs, and door/dash panels and parts up to 1996 can be used. Wait, now I'm confused. I thought any XJ seats required some bracket modification - perhaps I misread before? You have not misunderstood. You are correct assuming you have XJ buckets '93 or older. The floorpan bolt pattern (and shape) is completely different than the XJ. You would take your MJ bench seat brackets and grind the rivets off which separates the top have of the bracket from the bottom. That will give you the bottom of the bracket which mounts to your floor. Then use the top of XJ bucket brackets which will bolt directly to bottom half of your MJ brackets. Then you are good to go. From the cab forward, the floor pans are about the only difference between an MJ and an XJ. That and the coolness factor of course. :clapping: Link to comment Share on other sites More sharing options...
tbrand Posted November 21, 2010 Share Posted November 21, 2010 You have not misunderstood. You are correct assuming you have XJ buckets '93 or older. The floorpan bolt pattern (and shape) is completely different than the XJ. You would take your MJ bench seat brackets and grind the rivets off which separates the top have of the bracket from the bottom. That will give you the bottom of the bracket which mounts to your floor. Then use the top of XJ bucket brackets which will bolt directly to bottom half of your MJ brackets. Then you are good to go. From the cab forward, the floor pans are about the only difference between an MJ and an XJ. That and the coolness factor of course. :clapping: So what you're saying is, if I can find a set of MJ buckets, my life will be easier? I assume any MJ buckets bolt into any other MJ? Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 21, 2010 Share Posted November 21, 2010 Yes, if you have the MJ bucket seat brackets, any XJ/MJ bucket seat 92 and below will bolt directly to them with no modifications. You can also use the bench seat brackets, but one bucket will be fixed (not slide). I have not done this, but someone will chime in. Hey Don, Does your truck ALWAYS look like that? Have you ever considered driving it periodically? :rotf: I drive it most everyday Gary. That color kind of hides the dirt. :cheers: Link to comment Share on other sites More sharing options...
Akula69 Posted November 21, 2010 Share Posted November 21, 2010 And hey Jake - we still have Auburn. :yes: LOL Yup, until daddy comes clean with the NCAA :popcorn: And, I only wish my interiors looked that clean...you have a great lookin truck Don. :yes: Link to comment Share on other sites More sharing options...
johnj92131 Posted November 21, 2010 Share Posted November 21, 2010 Look for the 97 + outside mirrors. Larger and a better field of view. I have done that. Look at the 97 + door swap. Nice to get rid of the wing window. Have not done that. Second on the Laredo interior. Have done that. GM rear view mirror with map lights - Working on that. Grab the under dash lights from a Cherokee - the fit right in existing wiring. Link to comment Share on other sites More sharing options...
