MJ Bucket Seat Brackets - KS
87Warrior
My build plans have changed, therefore I have no need for this set of MJ bucket seat brackets. Instead of hoarding them I want to get them to somebody who can use them. They are in good, straight condition with only some minor metal pitting at the floor mount.
Pick up: $75 in Milford or Overland Park, KS
Shipped: $110 these are big and heavy, plus the cost of a sturdy box
Trades I will consider: Rubicon Axle Lock switch, Rubicon locker pump, Rubicon front locker, 97+XJ driver fender, factory MJ bumper, MJ replacement rocker panels, or 4.10s/locker for MJ D44. If you have something I might also want just ask!
Thanks,
Brett
  • 1 month later...
Make sure you specify what year those brackets are coming from , I'm assuming your 92" , if so those will only fit 91-92" MJ's . :smart: I already made that mistake ...
Not true. I'm using 88 brackets in my 91, and the part numbers are identical throughout the MJ years.
I never did find a set that fit my 92" , I ended up using 95" XJ brackets and modified them ... :dunno:
I was told they changed the floor pan design somewhere in those years .
False. My '88MJs and '92MJ all have identical floor pans.
Archived
