Darren Posted November 18, 2006 Share Posted November 18, 2006 How would an xj rail fit on my 'manche? Anyone know? Link to comment Share on other sites More sharing options...
beaterjeep Posted November 18, 2006 Share Posted November 18, 2006 IIRC, they are a little bit short. But then again, I may be wrong, it's been known to happen. Link to comment Share on other sites More sharing options...
Darren Posted November 18, 2006 Author Share Posted November 18, 2006 IIRC? IDKWTM (I don't know what that means) Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 18, 2006 Share Posted November 18, 2006 If I Remember Correctly Link to comment Share on other sites More sharing options...
Pete M Posted November 18, 2006 Share Posted November 18, 2006 If I Remember Correctly There's a 12" difference between an XJ wheelbase and a shortbed MJ wheelbase, so I'm guessing the rail will be about 12" short. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted November 18, 2006 Share Posted November 18, 2006 As others have mentioned the wheel base could be a problem. The XJ WB is 101" while the SB MJ is 113" and the LB is 119". ALSO, the XJ has its leaf's mounted OUTBOARD of the "frame". Many MFG's use the sides of the front leaf hanger as an attachment point for the rock rails. MJ's do not have this. again, this will depend on the manufacturer. Why not make your own? Many guys have on here. Take a look in the MJ PROJECTS area!! Good luck. CW Link to comment Share on other sites More sharing options...
87manche Posted November 18, 2006 Share Posted November 18, 2006 let's not also forget that the MJ frame isn't straight like an XJ's frame. It bends outwards just after the cab, so you'd have to cut the XJ rails mounts and then reweld them anyway. Might as well go cutoms. Mine are made out of some yota rails that were 78" long, just the mounting has been reworked. I'm a LWB though, and they're a bit short. Link to comment Share on other sites More sharing options...
