smg1986 Posted October 16, 2010 Share Posted October 16, 2010 I've got an 86 comanche xls, 2.5 tbi with 4x4. I am getting a lot of rubbing noise coming from my front tires. I am assuming its my bearings. Is this a repack the bearings job or are these a sealed unit where the whole hub assembly needs to be bought and replaced?? My wheels really show no play but the noise has to be bearings right? Link to comment Share on other sites More sharing options...
1987Comanche Posted October 16, 2010 Share Posted October 16, 2010 4X4 trucks use a sealed assy. I think a new one is around $90. Link to comment Share on other sites More sharing options...
Pete M Posted October 18, 2010 Share Posted October 18, 2010 could be a bad u-joint. jack up each corner, spin the tire and see where the noise is coming from. then turn the wheel a bit and rotate again. Link to comment Share on other sites More sharing options...
Garvin Posted October 18, 2010 Share Posted October 18, 2010 The other way (and be smart about this, no blaming me if you hit something!) is if you drive down the roadand turn the wheel to the weight on one corner. If the noise is louder when the weight is put on it, it's most likely a u-joint, if the noise is louder wehn the weight is taken off of it then it's most likely the wheel hub. It'll be about the same amount of tear down since when you remove the hub, the axle shaft just pulls out. Link to comment Share on other sites More sharing options...
