smg1986
Everything posted by smg1986
1986 Comanche XLS 127xxx on the clock. 4 banger 2.5l / AX5 / D30/D35 Sticker is long gone Currently located in the great state of Iowa Used as light wheeler/hauling/DD as of now. Bought from a guy who swore the master was low on fluid, since you couldn't shift into first without starting there and taking off. Replaced both master and slave immediately. Fixed floor board rust, starting to rust elsewhere now. Good running motor though, has yet to fail me other than misc easy fixes here and there. Red interior with buckets, POR15 for carpet, 5speed floor shift current owner - me
http://ames.craigslist.org/cto/2335394515.html
progress made slow but steady. cut out all bad metal, grinded the crap out of floor pans. now time to find a welder or decide to rivet/sealant route. then POR the whole thing and throw down some heavy duty rubber mats. i am thinking of leaving the giant wood board in the driver side floor as dumb as that sounds. its solid as rock and would literally need to be sawsall/torched out. it's sealed airtight and held for 2yrs+ if it ain't broke don't fix it right. also its not prone to rust ;) . pics of cut out metal driver side (notice wood) pass side (worse of the two) let me know what you think on either weld or rivets. i really am thinking a combination of the two. rivets where there is overlap or good metal and weld where there is no overlap and seal the seams on all both in cab and underbody.
so i've got metal cut out to fit holes. What is the best method to do this? Do i POR 15 the floor one coat then put down metal and seal it. or do i weld metal in, seal up all seams, and then POR 15 it? What is a good adhesive sealant to use?
I've seen way worse rust than this. I'll get a frame rail pic up sometime today. I'll be grinding and cutting this afternoon I'll keep pics coming
Ok so picked this baby up before i found this place. 1986 xls 2.5l 4X4. I recently after two moves and six months of just driving it around i started to dig in to it. Pulled the carpet and found, what else but massive rust and a present from the PO. Yes that is a block of wood in place of a driver side floor board. SO basically going to cut out all non surface rust, grind the heck out of everything, replace with sheet metal, and POR 15 the floor. Is this the way to go or are there better routes. I'm not looking for looks more just functionality. If it will drive and my foot won't go through the floor ill be happy. Also my passenger side frame rail is almost rusted through in a 2ft section. any fix ideas?! truck(bad shot) driver side pass side sorry for the massive pictures, sort of a newbie!
I realize there is 1000 threads on this, but thought i'd add one more. I've had a hiss at my feet since i bought this thing. Yesterday replaced check valve, and still the hiss. I can't imagine my booster is bad because brake pedal reacts normally...meaning not soft, not hard to press, just normal. I have a vacuum leak, that's a given, but where is it? the hissing disappears when the either the brake or gas pedal is depressed. The only thing it really affects that i know of is my idle. i'm right at 1200rpm now, but if i push the brake in and stop the hiss i drop down to about 800-900rpm. much appreciated in advance for help
Short shaft or Long Shaft? Clutch MC Question
smg1986 replied to hamilton's topic in MJ Tech: Modification and Repairs
agree with duster, i did the same thing. went to oreileys got the MC for like 30 bucks, threw it on there and bam done. -
http://desmoines.craigslist.org/cto/2240307847.html
whoa had something else on my mind. I meant JK its a 2008 Wrangler
clutch master cylinder leaking
smg1986 replied to Goblin22's topic in MJ Tech: Modification and Repairs
i bought an new aftermarket MC from o'reileys for $30 i believe, and have not had a leaking issue to this day. -
I've got a buddy you recently bought a 2008 XJ from a local dealership, he wants to get this built up to trail run and what not, but doesn't really have the funds. He calls the dealer and asks if they would sponser a jeep build, and they say they'll bring it up in there next budget meeting and if it works out they are on board. Apparently they've done it twice before over the years. Anyone ever heard of this being done? I'm sure an 86 comanche build is out of the budget/too old to advertise right lol
Fixed! well for now. Put a new lifter in. the old one had a hole in it. I know cam should be replaced but its just one lifter. Cam did look fine though. All is well for now until the cam goes!
I don't have a problem removing the head I'm just wondering if its cost effective to do a valve job or buy a 300 dollar 4.0 and swap. The swap being done by someone else. The swap is out of my league.
what can be done about a stuck valve? this was all caused by a bump i hit. how can i get the valve out or unstuck
i can push down on the rod and move it. None of the others do this. I'm lost. Not hugely knowledgeable about valves should i shop it or go it alone
i got the cover off and the last push rod is loose i can push the rocker off the spring by hand and spin the rod. Now what?
that's what i was thinking. I'll be taking off valve cover today. Hope i can find the problem. If nothing else I'll fix my leaky gasket
its an 1986 with the 2.5l
ok so I'm driving today and hit a railroad crossing not too softly. After the bump throttle body starts popping like crazy and severe power loss. I pulled the #4 plug out and the TB quit backfiring. What could this be? new plugs and wires. Also new cap and rotor. I'm stuck and can't drive on 3 cylinders. Please help.
1986 comanche is having radio issues. it used to work fine now all that comes through is static. Any thoughts? also what temp thermostat is best with the 2.5
Heat went out on me today. I shut it off and started smoking very little under the hood, and i could hear something bubbling out of my coolant resevoir? No coolant smell inside cab or white smoke out tail pipe. but no heat, definately no heat. what can i do to get my heat back. 1986 comanche xls 2.5 4X4 ax5 trans
I'm having clutch issues. I replaced/bled new master, and it worked for a while. Now its intermitten. it will work sometimes, and not other times. its smooth as butter when it does though. its awful getting it into reverse sometimes as well. ive replaced all the tranny fluid with redline, thinking of replacing slave except i don't have any fluid on the bell and my fluid level in the master never drops. ive heard the clutch arm can be bent but it doesnt appear to be. I'm going crazy please help. ive got a 86 manche xls with the 2.5. and it does have an external slave. positive. could this be the slave or more bleeding??
I've got an 86 comanche xls, 2.5 tbi with 4x4. I am getting a lot of rubbing noise coming from my front tires. I am assuming its my bearings. Is this a repack the bearings job or are these a sealed unit where the whole hub assembly needs to be bought and replaced?? My wheels really show no play but the noise has to be bearings right?
new owner. need a little help
smg1986 replied to smg1986's topic in MJ Tech: Modification and Repairs
thanks for the input ill try that. the noise I'm hearing is no way trans related. its in the front, i think its wheel bearings. ill try and put some pics up soon
