Door Panel Interchange
Do all 4 Dr XJ door panels swap directly from 84-96? I found a set of 97+ panels but all the plastic fastener locations are different. I may be able to score a set of nice '96 panels for the '90 MJ but I'm not sure if they changed the mounting locations when they added the Nader bars,etc. to the later model XJs.
while the topic is up...
will the early style panels fit the newer style doors?
The answer to your question is in the second post. The one right above your question.
YES, they fit. Colors may not be the same, but they fit.
I thought that the '97+ doors had the inner door handle in a different location. :dunno:
