rnobles Posted October 1, 2010 Share Posted October 1, 2010 I'm sure this has been beat into the ground SOMEWHERE on here, but i can't seem to find it at the moment. 86, 2.5 automatic (tf904) 2wd, d35. what gears do i probably have? 4:10? Link to comment Share on other sites More sharing options...
Geonovast Posted October 1, 2010 Share Posted October 1, 2010 Actually a good chance for 4.56:1. 4.10 is certainly a possibility. Best way to check would be to pop the cover. Link to comment Share on other sites More sharing options...
SW86 Posted October 1, 2010 Share Posted October 1, 2010 that is one low manche. i like :brows: Link to comment Share on other sites More sharing options...
TrailReadyMJ Posted October 1, 2010 Share Posted October 1, 2010 I agree, you may actually have the elusive stock 4.56s, but it's more likely to be 4.10s. I'm not sure if they ever put 4.56s in a 2wd :dunno: If you pull the cover, there will be numbers stamped in the ring gear. This will either have the ratio, or the tooth count on it. For the tooth count, just divide the larger number by the small to get the ratio. If you don't know when it was done last, it would be a good idea to pull the cover to change the gear oil anyway. Link to comment Share on other sites More sharing options...
rnobles Posted October 1, 2010 Author Share Posted October 1, 2010 Thanks guys. That wasnt really what i wanted to hear though.......lol I was hoping yall would way she has 3:55 or something She just has NO power at all!! wanted to try to GO to a 4:10 and see some power increase. (because you can find used gears in this range fairly cheap) guess I'm going to have to aim a little higher...... plan on going through the transmission, pretty sure its gunked up pretty bad and there is a little slip in there too. Link to comment Share on other sites More sharing options...
Pete M Posted October 1, 2010 Share Posted October 1, 2010 1986 is the wild card. you could still have 3.55s or 3.73s. Gotta check to know for sure. If you don't want to pull the cover, you could jack up one rear tire (trans in neutral) and rotate the tire around twice while counting the rotations of the driveshaft. if the driveshaft rotates 3 and a half times, it's 3.55. If it does a bit over 4 times, then 4.10s. Link to comment Share on other sites More sharing options...
Geonovast Posted October 1, 2010 Share Posted October 1, 2010 It would be cheaper to find an axle with the ratio you want than to install different gears. It's also usually not a good idea to install used gears in a different axle. Link to comment Share on other sites More sharing options...
mjeff87 Posted October 1, 2010 Share Posted October 1, 2010 on the 4.56's comments......they were only available (factory) from 87 to 89, and only behind an AW4. And yes, they did put them in 2WD's. Jeff Link to comment Share on other sites More sharing options...
