1J7FJ36L6KL461860
ComancheKid45
Year, Make, Model.
1989 Jeep Comanche Pioneer
Image, if available
Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase
4.0/AW4/NP231/D30/D44/LWB
Build date: (its on the driverside door sticker, in the form of month and year)
worn away :rant:
Current Location: Region will do, state, and area of state.
Shippensburg, Pennsylvania, South Central PA
Status: Is it still on the road, is it in the junkyard? Project awaiting work?
Project under way to give a still solid truck a new life
Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift.
Full Factory Skids (Gas tank skid mia but mouts were still there), Loaded interior minus full gauges, Truck was orgionally black but paint is in rough shape. cloth bench seat with column shift. Basically a high end Pioneer package back from the factory
Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort.
BJ Naugle (ComancheKid45)
  • 8 years later...
*X1 TRIM STYLE X1 - CLOTH BENCH
-SA Charcoal
133 Zone 33-Philadelphia
1AA U.S. Dealer Retail
5AM Largo Tracking
5KM AMES Department Stores
ADL Skid Plate Group
ALM Longhorn Southfork Package
APA Monotone Paint
BAY 105 Amp Alternator
BCY BATTERY, 58-475 CC
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRK Dana 44/226MM Rear Axle
DSA Anti-Spin Differential Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEC Front Left Side Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBD BEZEL-I/PANEL CLUSTER - BRIGHT
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKB MOPAR Hood Lock
K2X STRIPE/BADGE/MOLDING/COLOR
K3X STRIPE/BADGE/MOLDING/COLOR
KKE
LAF Seat Belt Alert-Driver Seat only
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFG Body Color Headlamp Bezels
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF5 Fuel Tank - 23 Gallon
PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6
QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
WJD 15X7.0 Styled Steel Wheels
XBS Pickup Box
XEE Fuel Tank Skid Plate Shield
XEF Transfer Case Skid Plate Shield
XEU Front Suspension Skid Plate
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGB 1 Additional Gallons of Gas
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z67 Left Front Spring Group XVI
Z86 Right Front Spring Group XV
Body Model JM62
Build date 11/8/88
  • 1 year later...
