207 transfer case issue
I'm doing the swap to make my 2wd to 4wd. I put the transmission and transfercase in now the transfercase doesnt want to shift out of two wheel drive. It shifted fine on the shop floor before I put into the truck. (the linkage isnt hooked up in the truck yet I'm just trying to shift it from the transfercase its self.) The only thing that is diffrent that i know of is i plug the vac lines because I'm not going to be using them. Since I'm permently locking my front. Any ideas on what it could be? Would be helpful. Thanks
904 (and 727) has a shallow output so it will work in a 23 spline 231, BUT you could also score a NP208 from a full size and it'll bolt right up, the 4 cyl couldn't possibly hurt it (unless you ran it with no oil) AND it has fixed yoke both ways!
