JeepinDev89 Posted September 16, 2010 Posted September 16, 2010 Ok, so I just picked up my 2nd 'manche its an 88 5spd 4.0 2wd Baltic blue. Found it in a garage. It had been sitting for a couple of years. Well $300 later she sits in my driveway. After trying to start for about 10 minutes she fired right up, so i had to go do a smoky burnout. posi and 2 gears not too shabby for a 22 year old truck with 238xxx miles. Just some little quirks to work out. Like fuel is spraying from the fuel pressure regulator, do I need a new one or just seals? Also, when I turn my headlights on my turn signal arrows light up, turn the turn signal on and it stays on no blinking. Any ideas? Besides that she just needs to get cleaned up a little and she will be road worthy. And how do i do pics so you guys can see some Comanche pics?
dasbulliwagen Posted September 16, 2010 Posted September 16, 2010 Do one or two more burnouts and you can get rid of your Puegot BA-10/5 transmission weather you want to or not. You might want to start keeping an eye out for an AX-15 to replace it sooner rather than later.
wannabeMJ Posted September 17, 2010 Posted September 17, 2010 Ok, so I just picked up my 2nd 'manche its an 88 5spd 4.0 2wd Baltic blue. Found it in a garage. It had been sitting for a couple of years. Well $300 later she sits in my driveway. After trying to start for about 10 minutes she fired right up, so i had to go do a smoky burnout. posi and 2 gears not too shabby for a 22 year old truck with 238xxx miles. Just some little quirks to work out. Like fuel is spraying from the fuel pressure regulator, do I need a new one or just seals? Also, when I turn my headlights on my turn signal arrows light up, turn the turn signal on and it stays on no blinking. Any ideas? Besides that she just needs to get cleaned up a little and she will be road worthy. And how do i do pics so you guys can see some Comanche pics? pics: photobucket.com flasher prob : most likely a ground on that line that is bad you can also try to check the flasher unit in the fuze box (the round thing in metal with 3 pins) or just replace it .its like 5$
