KMAPRO Posted September 16, 2010 Share Posted September 16, 2010 Just to catch anyone up who hasn't seen my other posts referencing my 87 MJ... 4.0 - 5 spd. 4x4..Replacing rear main seal because I have renamed the truck Exxon Valdez. Had to pull the engine to change the rear main seal because the oil pan was stuck to the bottom of the block. I pulled the engine, transmission and t-case all at once. I finally got the oil pan off by taking a 5-in-1 and gently working it around and around the oil pan. Then took a 3/4" wide chisel and gently worked the remaining gasket off - took about an hour and a half. I have also removed the rear main beaing cap. Here is why I am asking if the block is fubarred...I was checking everything out and planning the procedure for removing the upper rear main seal when I noticed that the little steel lip, between the seal and the back of the block, has the corner broken off. Since I have announced, in the past, that I am not a mechanic and just learing as I go, is this part of the upper bearing or is this part of the block? I am assuming - and hoping - it is part of the bearing. Is this critical? Should I replace the upper bearing or will it be OK? It only looks to be the corner of the keeper. Link to comment Share on other sites More sharing options...
jimoshel Posted September 16, 2010 Share Posted September 16, 2010 A pic would really be a great help. Link to comment Share on other sites More sharing options...
xjrev10 Posted September 17, 2010 Share Posted September 17, 2010 A pic would really be a great help. change the seal and run it haha yea post a pic :chillin: Link to comment Share on other sites More sharing options...
Geonovast Posted September 17, 2010 Share Posted September 17, 2010 If what you're talking about is what I think you're talking about, then no, it's not part of the bearing. Again, a picture would just be fantastic, and you might be ok... depending on the size of the chip and whether or not it's starting a crack. Link to comment Share on other sites More sharing options...
carnuck Posted September 19, 2010 Share Posted September 19, 2010 :redX: Link to comment Share on other sites More sharing options...
