Jeepcom23 Posted September 16, 2010 Posted September 16, 2010 I havent been on in awhile. BUT my mj is done and running great with her new heart ( 97 ZJ Engine ) But Ive still got an odd problem. My harmonic balancer arcs, in rhythm with the rpm, from the metal part of the balancer, across the little rubber piece to the other metal piece of the balancer. Ive checked my grounds and what nots but I can't figure it out Any ideas? Thanks! -Cody
dasbulliwagen Posted September 16, 2010 Posted September 16, 2010 Arcs like sparking? Electrically, or like metal to metal contact casuing a spark from friction? Sounds weird!
HOrnbrod Posted September 16, 2010 Posted September 16, 2010 Have you relocated the crank sensor from the flywheel to the harmonic balancer?
johnnyc Posted September 16, 2010 Posted September 16, 2010 Never heard of that problem before. The closest electrical components to the balancer would be the alternator or ignition coil. If it's in rhythm with the RPMs, I'm thinking ignition coil. Perhaps the coil housing is cracked? Just a wild guess.
Jeepcom23 Posted September 16, 2010 Author Posted September 16, 2010 Have you relocated the crank sensor from the flywheel to the harmonic balancer? Nope.
MJCARENA Posted September 17, 2010 Posted September 17, 2010 A guy in my jeep club had the same problem. Remove your belt and see if it still happens. If the belt is slipping or worn out it will create static electricty by slipping on the pully and it will arc. Try it and let us know. Here is a link to the thread http://www.virtualjeepclub.com/showthre ... park!-Help
Jeepcom23 Posted September 17, 2010 Author Posted September 17, 2010 sounds exactly like my problem ill check it out. Thanks again guys! -Cody
Automan2164 Posted September 17, 2010 Posted September 17, 2010 You have to get a video of this before you correct it. It sounds pretty weird. Rob L. :D
